Old 05-30-2008, 12:19 PM   #1
House of Darts
Liked 20 Times in 15 Posts
Default Wilwood Dynalite Brakes
I've got mixed reviews about the Dynalite brakes system. I'm looking to upgrade my factory disc/drum setup for a lighter and more durable system. I'm running a stocker @ 3300lbs and I'm looking to launch closer to 3000 rpns. Any thoughts/help? Thanks
House of Darts is offline   Reply With Quote
Old 05-30-2008, 03:05 PM   #2
Moparteacher
Default Re: Wilwood Dynalite Brakes
I installed them all the way around on my 69 Road Runner. I haven't ran the car yet, but they appear to be top notch. No complaints on the install.
Gary Weaver
Moparteacher@yahoo.com
Moparteacher is offline   Reply With Quote
Old 05-31-2008, 11:35 AM   #3
mrolds
mrolds's Avatar
I have the willwoods with the vented rotors on the front of my HEAVY Cutlass. I'm very happy with them! MUCH better than the 4 wheel drum it had! I had the same brakes on all 4 on my old Red 65 Cutlass.
Jeff Smith S/ST- Pro/ET 5102
Creating the streetable S/ST Olds
mrolds is offline   Reply With Quote
Old 05-31-2008, 11:58 AM   #4
Bob Verwold
Bob Verwold's Avatar
Don't know if this will help as I leave off a t-brake, but I have Willwoods with drilled rotors and never had a problem with stopping, even on short tracks. I did use their high temp fluid and spent quite a bit of time bleeding the system. Also went with their master cylinder and proportioning valve..................My car weighs 3020 with me in it ..........Hope this helps
Bob Verwold is offline   Reply With Quote
Old 05-31-2008, 10:25 PM   #5
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
I have Wilwoods on the front of my Demon.It stops great,better than with the O.E. drums.Make sure you take your time to center the calipers on the rotors and adjust the wheel bearings correctly.My Wilwoods spin very easily.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 06-01-2008, 04:12 PM   #6
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
I had no trouble with my front dynalite kit. Went together very easy. My rears on the other hand needed to be machined .025in to make them straight. Contacted them to let them know and the desk jockey wanted me to ship the rotors back for inspection in the middle of the race season. Ya ok. We came to the conclusion that i would send them back and I believe im getting a new set.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
