Old 05-27-2009, 08:12 PM   #1
Doug Estabrook
Default Single wheelie bar
Saw a picture of an A/SA Nova stocker at Maple Grove last weekend that had a single wheelie bar on it (car was built by Ken Keir). What's the advantage of that vs. a pair?
Thanks ahead of time,
Doug
Doug Estabrook is offline   Reply With Quote
Old 05-28-2009, 06:48 AM   #2
Bill Grubbs
Liked 564 Times in 66 Posts
Default Re: Single wheelie bar
Now, this is my opinion only .
Safety...Have you ever seen a double wheel wheelie bar break or bend just one tube? It gets ugly real fast. At the Memphis Nat. in 2007 A. Bertozzi "lost" one side of his wheelie bars, and crossed the centerline between the tree and the 60' cone. He almost landed on the car in the other lane.
Now, when a single wheel wheelie bar is designed correctly and a tube breaks you just come up higher (depending on the car it could be significantly higher). When the integrity of one of the three tubes is compromised the other tubes just fold up (if you are using heim joints).
There are some other minor benifits, but safety is the biggest on for me. I love my wife, and want to keep her around as long as I can.
Bill
Bill Grubbs is offline   Reply With Quote
Old 05-28-2009, 07:52 AM   #3
Dragsinger
Liked 99 Times in 60 Posts
The note from Bill seems reasonable to me. I also have begun to see a few of the single bars. My question, with a 12 bolt rear or other rear with cover, how is the bar attached/centered on the housing? Who is building or selling as a kit?
Larry Woodfin 471W
Old 05-28-2009, 10:58 AM   #4
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
I have seen this one but there must be more.
https://www.appliedracing.net/produc...9c2e240fb0e74a
Bob Pagano A/SA
Old 05-28-2009, 11:34 AM   #5
Bill Grubbs
The bottom mount on our wheelie bars is for the single tube. It was designed this way since it is in tension, the two upper bars are in compression which for a single bar would be a significant failure point.
The lower bar is mounted to a 4130 tube bent in a half moon, attached to the housing at either end of the center section, and then also in the middle to the center section. It almost looks as if it forms a cradle for the centersection.
Like I said before This is only my opinion, but it is the reason and way it is done on our car.
Bill
Old 05-28-2009, 12:44 PM   #6
mannymen
Liked 13 Times in 7 Posts
Bill can you post a few pics of your setup?
N/A
mannymen is offline   Reply With Quote
Old 05-28-2009, 06:46 PM   #7
Doug Estabrook
This is the wheeliebar set-up I was talking about.
Doug
