Old 08-13-2009, 05:25 PM   #1
Lyn Smith
Liked 973 Times in 195 Posts
Question Aluminum master cylinder?
When going to the after market front disc brakes is there a all aluminum master cylinder that will work instead of the plastic aluminum one that the companies sell?If so what does it come on.thanks
Lyn Smith is online now   Reply With Quote
Old 08-14-2009, 07:16 AM   #2
Lyn Smith
Question Re: Aluminum master cylinder?
Are there any regular automotive all aluminum ones that will work ok?
Old 08-14-2009, 09:53 AM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Aluminum master cylinder?
OEM Chrysler applications are popular that have the aluminum body and plastic resevoir.
I have a OEM manual disc/drum application from a late '70's Aspen/Volare on my OEM manual disc/drum Dart Sport. But I was considering doing to a larger truck version if I switch to aftermarket front discs.
I don't have any part #'s handy because I'm at work.
LOCOMOTION Racing
Old 08-14-2009, 11:10 AM   #4
FED 387
Liked 333 Times in 180 Posts
Default Re: Aluminum master cylinder?
--Lyn -----many of the late model GM cars specifically the corvettes utilize an all aluminum master cylinder and have a metal(steel) cap held in place with the old style snap ring setup--- they are very light only about 5 pounds each--- do not know how much trouble it would be to graft it onto your car tho---probably just hafta fabricate a plate to bolt onto your firewall and then make the appropriate rod to go from the B pedal to the cylinder--- should not be to difficult to do----- Comp 387
Old 08-14-2009, 11:52 AM   #5
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Lyn, 1979 Dodge PU 2wd is what's on mine. Aluminum body w/plastic resevoir. As long as it hasnt changed part #'s, it looks and works just like the Lamb high$$$ unit.....
Wade O
Old 08-15-2009, 06:29 AM   #6
bsa633
Banned
Wade O
Just dont forget to secure the "PushRod" the way Lamb has..been a couple of incidents ..Biondo..Woodro(i think) etc.
bsa633 is offline   Reply With Quote
Old 08-20-2009, 01:10 PM   #7
Dave Casey
Liked 774 Times in 164 Posts
mid early 80's S10 master with manual brakes. I have bought 3 of them and never used a proportioning valve. When you buy one, sometimes they come thru steel instead of aluminum, so check the box before you leave the store. Never had a leak issue.
Dave
Dave Casey 1330 STK
Old 08-20-2009, 04:04 PM   #8
Lyn Smith
thanks guys for all the info.
Old 08-21-2009, 05:02 PM   #9
Tod Lane
Tod Lane's Avatar
Liked 2 Times in 2 Posts
Dave
Disc/drum combo?
Tod Lane
Swartz & Lane 66 Nova
Swartz & Lane 79 H/CM Trans Am
Tod Lane is offline   Reply With Quote
Old 03-14-2010, 10:06 PM   #10
rawhide
Liked 7 Times in 5 Posts
Lyn,
There is a new Ford master cylinder on eBay that is aluminum with a steel cap. The eBay item number is 270360589638.
Rawhide
rawhide is offline   Reply With Quote
