Old 01-31-2010, 10:52 AM   #1
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
Default Stock Tech Question
My brother is looking to buy a local ET Bracket car and convert it to a Stock Eliminator car. Have most of the pieces to put it together. It has a factory floor but has the leaf springs moved into the frame, but the factory frame rails are still there with the factory spring mounting holes. So moving the springs back to the factory location is not a problem. But the car has aluminum wheel tubs. Is it possible to install steel wheel tubs in place of the aluminum and be legal for Stock,provided the steel is at least the same thickness as the factory?
Patric Fox is offline   Reply With Quote
Old 01-31-2010, 11:11 AM   #2
Philip Saran
Liked 14 Times in 11 Posts
Default Re: Stock Tech Question
Wheel tubs (steel or alum) are not allowed in stock.
You will need to replace the wheel tubs with stock pieces cut
out of a donor car.
Or run the car as a Superstocker instead and keep the wheel tubs.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 01-31-2010, 11:42 AM   #3
Patric Fox
Patric Fox's Avatar
Thank you, that is what I was afraid of,.
Old 02-02-2010, 03:36 PM   #4
MOVEMAN
Liked 11 Times in 2 Posts
Post Re: Stock Tech Question
I have a '97 Mustang that I was considering as a stocker project car. Can anyone give me a list of parts (chassis and engine/driveline) that are allowed to be changed/removed and/or altered? I know this may be a broad question so a reference point would also be appreciated! Is the NHRA rule book the only source for the information? Would there be a prefered combination in anyones view?
Thanks for any input!
Rich
MOVEMAN is offline   Reply With Quote
Old 02-02-2010, 03:53 PM   #5
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Rich
...not the only source, but probably the best. If you build to NHRA rules, the car will be legal for IHRA. You can refer to the IHRA book on their website, non-members as well.
In a nutshell, the suspension components must be stock or bolt-on replacement - no tubular components up front. Aftermarket adjustable struts/shocks in the stock locations are OK. The rule book should be your reference guide for engine building but working with a known engine shop familiar with Stock Eliminator rules "interpretation" is recommended.
Have fun!!
Dave Turner
SS/GT #1153
Old 02-02-2010, 05:17 PM   #6
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Rich, you have a PM. ....Tom
Old 02-04-2010, 05:52 PM   #7
foxy343
foxy343's Avatar
Default Stock Tech Questions
Wondering about NHRA Stock rules for framerails, can they protrude through the floor boards? They do right now stick up approximately one inch through the floor.
Also if there is a roll bar installed already do I still need a back seat? Can the seat be cut to accomodate the roll bar? Can the battery be relocated to the trunk?
About the trunk, it is pinned with hood pins right now, do I need to install the stock trunk hinges? I think a fuel cell in the trunk is legal now, any suggestions or recommendations?
foxy343 is offline   Reply With Quote
