Old 07-03-2011, 03:11 PM   #1
Lonnie Cox
Default Timing chain & gears recomendation I/SA
I have a small block in I/SA and need a recomendation for timing chain and gears, I have a comp cams gears and chain,but a lot of slop,thus could this retard the cam?
Thank You for all your help
Lonnie Cox is offline   Reply With Quote
Old 07-03-2011, 04:39 PM   #2
NWDragracing
Default Re: Timing chain & gears recomendation I/SA
Rollmaster. Check Ebay for the best price.
NWDragracing is offline   Reply With Quote
Old 07-04-2011, 08:10 AM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Timing chain & gears recomendation I/SA
New timing set? If the block was line bored/honed or it just has a smaller cam-to-crank measurement otherwise, you may need a slightly undersize chain set. Cloyes use to sell them. Chain tensioners are also made (Mopar and likely GM also), but I don't know if there are any disadvantages in a race application.
Old 07-04-2011, 12:33 PM   #4
Dragsinger
Liked 99 Times in 60 Posts
The Cloyes "Hex-A-Just" is a good choice. In addition, it is available in several chain lengths [ -.005 and -.010]
Larry Woodfin 471W
Old 07-07-2011, 07:05 PM   #5
njk53
X2 on the Rollmaster. Fits much better than the other brands but, a little pricey.
Nelson Kowal
Stock 345
Old 07-07-2011, 09:32 PM   #6
Ed Wright
Ed Wright's Avatar
Originally Posted by njk53 View Post
x2 on the rollmaster. Fits much better than the other brands but, a little pricey.
x3!
Ed Wright 4156 SS/JA
