Old 04-03-2012, 02:47 PM   #1
cad
cad's Avatar
Liked 93 Times in 52 Posts
Default 55 gal drum: What transfer pump to use?
I usually split a drum of fuel with a friend, but this year, we both plan on getting our own drums.
He has an expensive transfer pump. A couple other friends recommended a plastic red/clear inexpensive pump that has a palm sized "bellows" that they say works fine.
Example
What do you use?
Thanks
Clark
Old 04-03-2012, 02:58 PM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: 55 gal drum: What transfer pump to use?
I have bought fuel by the drum for years. Gas and methanol.
I use the hand pump your friend described. They sell for less than $20 and work fine. When the drum is near full....it will syphon and you don't have to pump it.....Takes maybe 5 minutes to fill a 5 gallon jug.
When you race a methanol powered dragster with fuel injection....you burn a lot of fuel and buying it by the drum saves a lot of $$$
Rich Biebel
S/C 1479
Stock 147R
Old 04-03-2012, 03:17 PM   #3
cad
cad's Avatar
Thanks Rich. We also run methanol, but our juniors only use about a gallon each per weekend, so I dont keep more than 10 gallons on hand.
We used to have a circle track parts house in town, but it closed. Looks like Speedway in Lincoln has them for $15. My VP guy says he'll sell me one for $15.
No smoking in my garage...LOL.
I just wanted to confirm they arent junk.
Old 04-03-2012, 03:54 PM   #4
Myron Piatek
Liked 138 Times in 51 Posts
Thumbs up Re: 55 gal drum: What transfer pump to use?
The plastic red/white pump sounds like this one, which is what I've been using for years. One was getting old so I bought a spare over a year ago, but the old one is still pumping. Good deal if available for $15.00 locally.
http://www.summitracing.com/parts/AAF-ALL40114/
Old 04-03-2012, 04:11 PM   #5
PETE PEERY
Liked 33 Times in 11 Posts
For a fast and efficient method get a ball valve with pipe threads and install galvanized pipe on one side and hose in the other. Install in small hole of drum and a tire valve stem in large bung and pressurize with air. This will transfer fuel very quickly and no mess.
Pete
PETE PEERY is offline   Reply With Quote
Old 04-03-2012, 09:01 PM   #6
63corvette
Liked 359 Times in 103 Posts
Pete
Be very afraid of this method.
You are building a bomb with this.
Air and gas in a barrel is not safe plus a barrel is not rated as a pressure vessel.
If you are going to do this at all use nitrogen to pressure a gas filled vessel.
Be very afraid on this method as noted as gas and air/oxygen do not mix safely in a closed vessel.
My 2 Cents
Rick Cates
63corvette is offline   Reply With Quote
Old 04-03-2012, 09:24 PM   #7
KRatcliff
Liked 534 Times in 143 Posts
Do you have any fuel barrels that don't have any air in them? Unless a fuel barrel is completely filled with fuel then they are all potential bombs. As is your fuel can, fuel cell, fuel tank, etc...
I read it as the air is pushing out the fuel out the hose, not building a bomb.
KRatcliff is offline   Reply With Quote
Old 04-03-2012, 10:01 PM   #8
63corvette
There is very little air/oxygen in the barrel as you empty them.
It is made up for the most part by fumes from the gas itself which vaporizes as you give it space in the barrel.
I worked in the oil and gas industry for 40 plus years and I can assure you if you use air to pressurize a barrel at some point it will explode. You may get away with it for years but at some point it will possibly end your life or leave you with a very bad injury of some type.
Trust me on this one a partially full barrel of gas is a very dangerous thing. It is much safer as a full or completely empty with the bungs out of it and vented and NOT pressurized.
I witnessed my step father loose a leg to a 55 gal barrel using it empty for a ladder/platform to stand on. It was a hot day and built pressure inside and exploded with him on top. It blew the top out of the barrel and severed his leg just below the knee.
Used barrels of any type can be very dangerous if not handled correctly and pressurizing them is improper use.
Like Bob said buy a pump. It could save your life or at least not injure you.
My Experience Here
Rick Cates
Old 04-03-2012, 10:22 PM   #9
KRatcliff
I think you are reading it wrong as far as pressurizing goes. I am reading it as adding slightly more pressure than the ambient air pressure which would flow the fuel from one barrel to another. It takes less pressure to move the fuel than what is within the barrel when they "pop" with temperature changes.
It is exactly the inverse of siphoning where you are pulling a vacuum. In both instances you are adding air/oxygen to the original barrel. And you are adding air/oxygen when using a transfer pump.
Even the fuel tank in your car/truck has an air vent that draws air/oxygen into it as the fuel pump removes it during consumption. I think you and Bob are referring to situations that truly pressurize the barrels way beyond what was suggested. YMMV.
Old 04-03-2012, 09:27 PM   #10
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Pete
When I worked at the shipyards I saw a crane operator almost take head off with the end of a 55-gallon drum...............
He laid the drum on its side attached a transfer hose to the lower bung and an air hose to the upper bung to transfer diesel fuel into the crane.....
He turned on the air and it blew off the end of the drum killing him instantly and blowing 55 gallons of diesel fuel in all directions......
BAD IDEA........
Save your life and buy a $20 plastic pump from Graingers
Bob
Bob Mulry 7516 STK
A & M Motorsports
