Old 10-04-2013, 12:07 PM   #1
hardtimes
Default Help with front suspension
I am building a 67 Mustang Coupe bracket car. It will have cal-tracs on the rear.
Looking for any hints/help with the front suspension i know stockers have very good working suspensions. Anything that could help i would appreciate, try to get the car to transfer weight as good as possible. will be running a small block.
hardtimes is offline   Reply With Quote
Old 10-04-2013, 12:57 PM   #2
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: Help with front suspension
Very familiar with that suspension.
If you are not yanking the wheels off the ground.
Good top grade rebuild part and a front drag shock work well.
Would brace the Shock Towers.
IF you are pulling hard wheelies contact CalTrac or go on Mustang blogs to counter the return to earth.
ON hard landings the Mustang front ends tires will camber and toe out shaking a bit until the front end settles.
View the Stocker races when the Mustang Stockers launch.
You will see what I mean..
Dan
Old 10-04-2013, 01:22 PM   #3
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Thumbs up Re: Help with front suspension
Contact Alex Denysenko at MoneyMaker Racing in Indiana....a Caltracs dealer, SBF Super Stock and Stock competitor and just an all round good guy. He will "set you up".
6646 1/2 W. Johnson Rd.
La Porte, IN 46350
ph: 219-861-1214
fax: 219-871-0755
alt: 708-805-0000
monymkrssla@aol.com
Dave Turner
SS/GT #1153
Old 10-07-2013, 11:13 AM   #4
hardtimes
any other tips/suggestions to help loosen the front end up to help transfer weight and hopefuly pull some wheelies like a stocker
Old 10-07-2013, 01:06 PM   #5
Bill Harris
Liked 26 Times in 13 Posts
x2 on Alex.
You can look at the FoMoCo front end stuff at http://www.opentrackerracingproducts.com/
They have all rollerized front end stuff that will make the thing amazingly loose. Need good shocks to go with that stuff.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 10-07-2013, 02:42 PM   #6
FLEMING
Liked 55 Times in 26 Posts
La Porte, IN 46350
ph: 219-861-1214
fax: 219-871-0755
alt: 708-805-0000
monymkrssla@aol.com
What he said!
FLEMING is offline   Reply With Quote
