Old 06-28-2014, 08:36 PM   #1
js72mav
Default Hoosier Radial ?
I am currently running the 30 x 9 Hoosier radials on my super stocker (GT/LA). Up until now i just foot braked the car, now i am starting to use a trans brake. My question is does the radial tire hook the same with the trans brake shocking the suspension as it would foot braking where the suspension is loaded? On my couple test passes i blew the tires off, dropped a little more air pressure in the tires and it did the same. Any advice would be great, thanks!!
js72mav is offline   Reply With Quote
Old 06-28-2014, 08:46 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Hoosier Radial ?
Radials work fine with Trans brakes in SS. That is what most people use, unless trying to slow the car down. 9" is a tad small.
Ed Wright 4156 SS/JA
Old 06-28-2014, 11:39 PM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Hoosier Radial ?
As noted, radials are faster and 9" is on the narrow side. But they are also more "sensitive" to track conditions than bias ply slicks. Adding the trans-brake launch can be putting more "responsibility" on track prep. Perhaps some suspension tuning could help, like stiffening the rear shocks.
LOCOMOTION Racing
Old 06-28-2014, 11:47 PM   #4
SStockDart
SStockDart's Avatar
Liked 606 Times in 213 Posts
Soften the rear shocks for a questionable track.......stiffen them up a little if the track has grip. Additionally, the trans brake will provide an immediate lift to the front, as compared to foot braking. Very important to have the proper front shocks as well. Stay at around 20 psi with the 9 inch radials (Ed may disagree, he has more experience with them)......and adjust the shocks.
Old 06-29-2014, 10:10 AM   #5
Tom Meyer
Liked 354 Times in 120 Posts
When I was running my car, 66 chevy II 283 SS/LA 3200 lb with a brake on 9 in tire at 23 lb air and right foot to the floor 6500 rpm I had a few problems hooking at hot tracks. I ended up chiping it down to 5700,and had sixty foots in the high 1.30s. had to do some ajustments to shocks but it still worked well. Tom
Tom Meyer 5240 SS Stock ???
Old 07-05-2014, 09:59 AM   #6
Bryan Worner
Liked 535 Times in 86 Posts
Get Mickey Thompson radials! They hook anywhere!!
Bryan Worner is offline   Reply With Quote
