Old 10-02-2014, 11:35 PM   #1
firebird
Default powerslide?
i'm having issues with a glide. first blamed the new 7"convertor-then new kit -including band-then dual ring accumulator ----pressures within specs--the problem is that it acts like it slips in low gear-went up and down with the launch rpm--3200 #car--327 engine----high gear it seems to hook.what am i missing?----thanks for any help
firebird is offline   Reply With Quote
Old 10-03-2014, 07:58 AM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,984 Times in 597 Posts
Default Re: powerslide?
If it is slipping in low gear it will burn the band up almost immediately. Is the fluid burnt smelling? what makes you suspect that the trans is slipping in low gear? Are you using a trans brake? if the band is slipping the car will try to back up when you get up on the brake.
Mike Pearson 2485 SS
Old 10-03-2014, 09:48 AM   #3
Mickey Whaley
yep adjust the band check the fluid for smell and make sure the shifter cable is in check meaning its all the way in low gear
Mickey Whaley is offline   Reply With Quote
Old 10-04-2014, 09:35 AM   #4
ATI Performance Products
Sponsor
ATI Performance Products's Avatar
Liked 9 Times in 1 Post
Alum or steel drum? Red or Kevlar / Carbon band? What is your adjustment? What was it when you checked it and did you have to change it? What is your line pressure that is in spec? The other guy posting is correct that if it does slip in low gear, its gonna do it a couple times and then stop when it doesn't move anymore. So its usually not something that comes and goes so I think it might be something else you are feeling.
ATI Racing
ATI Performance Products is offline   Reply With Quote
Old 10-04-2014, 05:29 PM   #5
firebird
thanks for the input----with my combination i can't get a good 60 ft (1.80) . one time during the burn-out i was told the tires quit turning----with the 7" convertor -456 gears -9"slicks i thought i would at least pick the front end up---i have no burnt fluid-new kevlar band---steel drum---what rpm launch do you think? shift at 8-85----could it be the new convertor? .
Old 10-04-2014, 05:49 PM   #6
ss wannabee
Liked 7 Times in 7 Posts
Is this a foot-braked et-bracket type car? I'm wondering if you got too much converter
for your combo....assuming you went to the 7" after running an 8".
ss wannabee is offline   Reply With Quote
Old 10-07-2014, 01:20 PM   #7
Rick Schilling
Liked 14 Times in 10 Posts
Especially the cable adjustment. I had an issue with cable/linkage adjustment on a glide that caused slippage in low if I held pressure on the shifter (as if to hold it in gear).
The shifter was actually traveling beyond where it needed to be and the car would porpoise on the launch.
Some fine tuning and learning to leave the shifter alone until it was time to use it cured the problem.
Rick Schilling is offline   Reply With Quote
