Old 10-04-2014, 10:25 PM   #1
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Default GM A Body front springs
My chevelle has the moroso 47160 springs, lightest in the catalog for 68-72. Now that the ride height is where I want it the springs are dead, too much cut off. Does anybody know which spring will have the same dimensions but be another 'step' softer? Possibly a 64-67 spring or maybe first gen camaro?
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 10-04-2014, 10:45 PM   #2
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Default Re: GM A Body front springs
Chris…I had a 69 Big Block Chevelle and I ended up using some left over 47195's from my Nova Super Stocker. They are @ 1-1 1/2" shorter and have a comparable spring rate, not to mention easier to install. Car sat @ 1 1/2" lower than stock with 29" front tire and 30" rear slick. Hope this helps…Maurice.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 10-05-2014, 02:33 AM   #3
67 Post GS
67 Post GS's Avatar
Liked 61 Times in 11 Posts
I use a 64-67 spring in mine. Can't remember the number off hand but I can look if you want.
67 Post GS is offline   Reply With Quote
Old 10-05-2014, 10:40 AM   #4
Run to Rund
Liked 55 Times in 28 Posts
64-7 springs have both ends "tangential" meaning the end coil is round and wound tighter to the previous coil. 68-72 springs have the bottom tangential and the top "square" meaning the end coil is flat, not round in cross section. The frame pockets are different to mate to the correct spring.
