Liked 169 Times in 53 Posts
I bought a set of Calvert springs for my Nova stocker last month. Today I finally got around to putting them on. When I went to raise the right side spring up to hook up the rear spring shackle it was about 4 inches off to the inside from lining up. Both springs have the same part number on them. Are both springs supposed to be the same or is there a left and right side. It looks like I have 2 left side springs. I can't get in touch with John Calvert and I'd like to get these things on this weekend if possible. Anyone out there know what's going on with these?
Bill Bogues 4696 STK |
Liked 237 Times in 126 Posts
I have two sets for my 68 Mustang, one raised and one lowered. I put them side by side when I got them and the pairs of each set were identical. Theres a difference between the front and back end, of coarse , but no right and left that I know of.
EDIT: I just went down and looked at the lowered set in the garage and the part numbers are consecutive. They don't match. One is 39753 and the other is 39754 for my Ford. They are split mono 2000 springs. The large number on the spring label has an "L" to indicate Lowered and one has the big sticker at the front and reads LF while the other has the big sticker at the rear and reads LR. Dale Last edited by FireSale; 12-13-2014 at 09:37 PM. Reason: Corrected a part number |
Liked 286 Times in 88 Posts
Bill…Your front spring perches may have to be loosened off and repositioned. MB.
Maurice ; That's the first thing that I did. It brought the spring to within about an inch of being lined up , but you still have to f orce the spring over to get it to line up. That's not going to work with the spring in a bind. Thank's for the response. Bill
Liked 33 Times in 16 Posts
Bill - I have not tried it before in the order you are attempting (front first, rear last), but I don't see where that would be an issue. Maybe reverse the order just for the heck of it to see what gives. You doing this on jackstands or a lift?
Rich Taylor I/SA - 321 |
Liked 11,030 Times in 2,266 Posts
Check the tie bolt placement in relationship to the front eye. If different it will change wheel base.
