Liked 327 Times in 87 Posts
What's your opinion on bellhousings.... I remember reading a thread that mentioned one was more friendly for making adjustments.
Liked 293 Times in 65 Posts
I have the QuickTime with the window, which makes adjustments a piece of cake. The drawback of the QT is that it's not very deep, making it a challenge to strike a balance between having enough air gap and enough clearance between the fingers and the TO bearing. I've heard Browell makes a really nice unit, but haven't seen one so can't say if they're worth the coin.
Liked 510 Times in 117 Posts
I have run both bellhousings since I converted mine to a stick several years ago and did find the Browell to be the best. I found that the QT I always needed the most offset block dowels to center it. The Browell was dead on. Plus Brian will do anything to the housing (as long as it stays within safety rules) to help make clutch adjustments easiest as he is the one to certify it. Never a problem with bearing clearance and he'll put any style of clutch fork you want to use.
68 Chevy11 327 F/S |
Liked 172 Times in 46 Posts
Had to do a lot of work on my Quicktime to make the clutch fork work not a lot of room. Brian makes a great piece and is very willing to work with you. Wants to me to change out my Quicktime just have not done it yet.
Dirk
Dirk Olson 5036 STK |
Liked 807 Times in 247 Posts
My only issue with Browell is having to take out the second mortgage on my house to buy one... I'll stick with Quicktime. Either one is a huge improvement over Lakewood both from a quality and weight standpoint.
Jim Caughlin SS 6019 |
Liked 11 Times in 4 Posts
This was not my experience. The cost of my Browell was very competitive with the Quicktime. The main difference being shipping because you cannot order the Browell from Summit and get free shipping. I would call Brain and ask for a quote.
The Browell is an awesome piece and Brian is very helpful. |
