Old 03-15-2016, 07:22 PM   #1
Moparteacher
Default c4 build
Hi everyone, long time no post.
I'm building 1973 Ford c4 transmission for friend. It'll be going behind a hot little 347. Owner is anticipating 500 ft. lbs. of torque.
I would appreciate any suggestions to improve the build.
Here's what I have so far:
TCI input 24/26
C type servo
Alto reds and steels
Kevlar band
5 pinion front planetary
Shift kit hasn't been purchased yet but a B&M or Fairbanks id being considered.
Are there any other improvements I should make and will these parts hold in a c4?
Thank you
Gary Weaver
Moparteacher@yahoo.com
Moparteacher is offline   Reply With Quote
Old 03-15-2016, 07:46 PM   #2
Rsmith38
Liked 28 Times in 15 Posts
Default Re: c4 build
Sugest you talk to joel - Joels on Joy - He built all the C4's for the CJ Mustangs
Rsmith38 is offline   Reply With Quote
Old 03-15-2016, 11:42 PM   #3
Lou Jeffery
The parts you have listed are a good start. The key to a high torque high RPM C-4 is replacing the thrust washers with Torrington thrust bearings. Once that is under control you may consider a manual shift fixed line pressure valvebody. The traditional shift kit with vacuum modulator line control and governor can be marginal with that much engine power. The Ford C-4 is an excellent transmission, It is light weight, fits well and has reasonable durability.
Lou Jeffery is offline   Reply With Quote
Old 03-16-2016, 06:26 PM   #4
Moparteacher
I appreciate the responses.
Gary Weaver
Old 04-12-2016, 04:29 PM   #5
ShadowLands
ShadowLands's Avatar
Ditto.
ShadowLands is offline   Reply With Quote
