Liked 72 Times in 36 Posts
How does one remove Decals from an aluminum Trailer without messing up the paint
Thank You Kenney Kelley |
Liked 685 Times in 196 Posts
I took 5 dealer decals off my new ATC trailer. I used my heat gun to warm them up a little and they peeled right off in one piece. My trailer is not painted it appears to be an anodized finish.
Mike 7570 A/SA Last edited by Mike Gray; 08-25-2023 at 11:51 AM. |
Liked 5,114 Times in 1,948 Posts
Be careful . HF type heat guns are too hot, IMO.
Use a hair dryer, if you've got one. Peel at a sharp angle,..slowly . Then use a rag with some gas to get the glue off. If It's white , baked on aluminum, you won't hurt it. If it's paint out of a spray gun... No tellin' what could happen.
Liked 859 Times in 234 Posts
put it out in the sun and spray them around the edges with WD40 . it takes a little time to get going but once you can get it behind the edges, they come off pretty good , with no damage to the paint.
It also works really well for cleaning up the glue residue left behind.
Liked 5 Times in 4 Posts
I also like to use those plastic razor blades to get under the decals, and get things started without the risk of paint damage
Liked 918 Times in 258 Posts
Hair dryer, WD.
