Old 03-06-2012, 12:43 AM   #1
Dick Butler
Liked 32 Times in 19 Posts
Default WTB 56 2 x 4s for corvette
I know there are clones, I know I could use a late model motor but I am hoping to get someone to sell an original Corvette 2 x 4 carbs, even if they need work.FOUND THE MANIFOLD>
I am building a tribute car that would be better if it had all the right stuff.(for me)
I will buy manifold, and carbs separate if you have them. Thanks Dick Butler
937-623-8126
Also want used Stahl fenderwell headers cheap... Thanks I would REALLY like to get back MY Stahl headers I sold a couple of years ago....
I sold them to a person on this site...
Old 03-06-2012, 03:22 PM   #2
gmeyer
Liked 35 Times in 16 Posts
Default Re: WTB 56 2 x 4s for corvette
Don O Malley has a 58 corvette 2x4 set up for sale
greg SS/GT 3592
gmeyer is offline   Reply With Quote
Old 03-06-2012, 03:47 PM   #3
FED 387
Liked 333 Times in 180 Posts
Dick--- look on Ebay currently several carb/manifolds combo also just carbs and just manifolds for sale plus correct air cleaners too---some with buy it now--Dick
Old 03-25-2012, 05:50 PM   #4
Wayne W
Wayne W's Avatar
Liked 3 Times in 1 Post
56 carbs and early 57 carbs are hard to find. They have the idle air screws near the secondary throttle shaft in the base plate. I have a set if you need casting numbers. I also have a 56 Chev .
Wayne W is offline   Reply With Quote
Old 03-31-2012, 10:09 PM   #5
Dick Butler
Thanks for suggestions. I have found a couple of sets which are "rare priced". I will keep watching as I am not needing them today. The body work and chassis are nearing completion. Then as I can I will assemble the rest. Need to sell the Belvedere to create more cash flow for Delivery project.
Old 03-31-2012, 11:02 PM   #6
FED 387
Dick-- 1956 Chevy 2x4 manifolds #3728725 1st design and 2nd design #3731394 manifolds with 4 individual holes for carb barrels(1956 only and very very early 1957) versus #3739653 (1957-1961) which had 2 holes and one large figure 8 hole for each carb are available for anywhere from $200 to $700-$ 800 depending on condition and who you buy them from. Carbs(2419s & 2362s) are priced all over the place again condition is the pricing factor here...might do this piecemeal and get what you can afford now and as $$$$$ permits make a purchase of the rest of the parts as you go along---pay particular attention to bolt holes( manifold to head) on engines that have been decked the bolt holes will generally crack at 4 & 8 oclock positions ya hafta look very carefully---also look under the oil shield the tend to rot out in there - plus the heater hose nipples usually are rusted into the manifold very touchy repair to do properly----Comp
Old 05-01-2012, 10:12 AM   #7
Jeff Lee
Jeff Lee's Avatar
937-623-8126
Here you go!
http://www.hemmings.com/parts/item/2542.html?refer=news
Jeff Lee 7494 D/S '70 AMX
