Old 01-24-2009, 05:19 PM   #1
hotrod
Default Baseline T-Stop set up
Need a little help here guys...Car i bought runs 5.85 very consistent all out....i wanna run S/R 6.40 with this car. I have the throtle stop rpm set @ 4100 and gonna be shifting on time...........How much amount of time do yall think it needs and where should i hit the t-stop in the run??? Thanks guys
hotrod is offline   Reply With Quote
Old 01-24-2009, 07:33 PM   #2
Lou SG2340
Default Re: Baseline T-Stop set up
Mine is stop on at .20 @ shift at .40 but I am 2200lb 565. Every car is different.
The sooner you can turn the stop on & get in high gear the less time you will be on the stop.
Lou SG2340 is offline   Reply With Quote
Old 01-24-2009, 08:07 PM   #3
Duane Dagostino
Lou...your on at .200 or .020...just asking..thanx
Duane Dagostino is offline   Reply With Quote
Old 01-24-2009, 11:30 PM   #4
63corvette
Liked 359 Times in 103 Posts
Another part of the equation is where your starting line chip is.
I run .07 stop on shift to high at 1.0 with a 565 BBC with std Brodix BBC heads.
Starting line chip of 5000 to 5600 depending on what the adjusted altitude is.
Good Luck with the setup. It takes a few passes to decide just what the car likes and they are ALL different.
My 2 Cents
63corvette is offline   Reply With Quote
Old 01-25-2009, 01:21 AM   #5
Jeff Beckman
Jeff Beckman's Avatar
Send a message via AIM to Jeff Beckman
Talking Re: Baseline T-Stop set up
With the limited amount of time you are trying to loose, dont wad the tire up and put the car flat on its nose. It will not recover the same as a car with a little more zoom. I might try leaving soft, say 5000 RPM and shift to high gear at .01, that might scrub most of your half second of stop time. Then raise your stop RPM and see what it runs. As LITTLE stop as early as possible, be gentle on the load and unload of the suspension for repeatability. That be maybe my 2 non cents worth. Or you could ask the HITTER! Sorry Dude, wherever you are, but you brought this fun on yourself.
Jeff Beckman 318J ET, SG
318T SC
Jeff Beckman is offline   Reply With Quote
Old 01-25-2009, 09:14 AM   #6
CBS
CBS's Avatar
Liked 4 Times in 2 Posts
ouch!
CBS is offline   Reply With Quote
Old 01-25-2009, 10:00 AM   #7
VanPelt
VanPelt's Avatar
Another well said statement for the day Jeff! This is more fun that a comedy club. Keep it up.
Cheers
VanPelt is offline   Reply With Quote
Old 01-25-2009, 10:14 AM   #8
Dave Steltz
Dave Steltz's Avatar
5600 leave, then on at .1 for me..then I kill it to almost an idle...Alcohhol injection for me....Like its been said everycar is different..
I think most cars with a gas carb like about 4000 rpm, injected seem to work better much lower...
I'm a hitter !!!! (got lots of lumps on my head to prove it)...oh I thought you meant hitting yourself in the head when you do something dumb...Ha...
Dave Steltz 135G SG/SP/SST
BIAECH Racing Team
Dave Steltz is offline   Reply With Quote
Old 01-25-2009, 01:28 PM   #9
63corvette
If hitting yourself in the head counts as being a hitter I am a professional hitter. I have been drag racing now for 40+ years and have lots of lumps to prove it!!!!
My first trip to race Indy first round was a .001 red light and when I ran it out it ran 9.903.
There was lots of hitting and lumps from that one when I saw the slip and I will NEVER forget that one.
It still hurts when I think about it!!!!!!!!
My 2 Cents
Old 01-25-2009, 05:56 PM   #10
Lou SG2340
Sorry I was thinking. .020 & .040
