Old 02-13-2009, 09:11 PM   #1
Billy Harper
Liked 138 Times in 22 Posts
Default light weight spool & gears
who makes good light weight spool & gears
BILLY HARPER
Billy Harper is offline   Reply With Quote
Old 02-13-2009, 09:30 PM   #2
Shawn Blair
Shawn Blair's Avatar
Talking Re: light weight spool & gears
Mark Williams aluminum spool. They also lighten gears.
Shawn Blair 6383 SS 634 STK
Shawn Blair is offline   Reply With Quote
Old 02-14-2009, 10:02 AM   #3
danny waters sr
danny waters sr's Avatar
Thumbs up Re: light weight spool & gears
Moser engineering///// the best !!!!!
Old 02-14-2009, 01:06 PM   #4
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: light weight spool & gears
I would second the moser stuff. If you use the moser alum spool you will most likely have to send them your axles to have the splines cut a little longer as they run the splines in the spool all the way from one end to the other. It cost a little more to do it this way but looks to make it alot stronger and less likely to strip the splines out of the alum spool as I have seen with some of the others.
Old 02-14-2009, 02:11 PM   #5
Rod Greene
Liked 242 Times in 81 Posts
Mark Williams sets the standard that others shoot for. I have run the MW aluminum spool and light weight axles since 1999 thousands of hits never a problem. That is with a 7000 rpm stick shift launch. Now that the car is sold and has an slush-o-matic in it the parts should last forever.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 02-14-2009, 02:48 PM   #6
bsa633
Banned
M/W is far better quality than Moser..but more expensive too..used both..no real problems with Moser...I just like to have better quality stuff...
bsa633 is offline   Reply With Quote
Old 02-14-2009, 04:57 PM   #7
Joe Martens
Joe Martens's Avatar
Liked 198 Times in 71 Posts
Mark Williams has my vote. Mike Pustelny from MPR is a dealer for them and he can get you the best prices on their products. 810-798-8998.
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
Old 02-14-2009, 06:30 PM   #8
NHRA1877
Not trying to hyjack the thread but i was wondering. How much has anyone picked up going from a normal 30 spline moser kit to a good light weight package? I know its making your rotating parts lighter which is always a good thing but how much will it actually help. Also anything about ceramic in the rear?
NHRA1877 is offline   Reply With Quote
Old 02-14-2009, 09:03 PM   #9
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Guys i'm not trying to stir the pot here. But in my 0pinion the moser stuff , isn't really that nice i think their quality is poor . If you want cheap than go with Moser . I have run a chassis shop for nearly 20 years, and have used parts from Moser ,Stange, and Mark Williams. The M/W is stuff is very well made but kinda exspensive . the parts from Strange eng. are very well made , and priced much better. My first choice is always Strange.
Mark Markow is offline   Reply With Quote
Old 02-15-2009, 08:31 PM   #10
John Duzac
John Duzac's Avatar
Liked 83 Times in 20 Posts
Smile Re: light weight spool & gears
Moser Aluminum spool lasted me for about 20 runs and then the ring gear side broke. This was last year at the Memphis Tn. points meet. I replaced the spool with a steel Moser spool and put many runs on it without a problem.
John Duzac D/S 4448 STK
John Duzac is offline   Reply With Quote
