Old 02-25-2009, 08:45 PM   #1
drag55
Smile 2000 S-10 Stocker
I need some help. I want to build a S-10 4cyl. auto stocker. I need some advice on what trans to run. What rearend gears and so on. Any help will be greatly appreciated. Thanks Ron
drag55 is offline   Reply With Quote
Old 02-25-2009, 10:10 PM   #2
Default Re: 2000 S-10 Stocker
129 hp is kinda high for a 134 ci 4 cylinder.
Old 02-26-2009, 10:38 PM   #3
drag55
So i take it you don't like that combo. It is what i have and thought it would be kind of different. Any input would be appreciated. Thanks Ron
Old 02-28-2009, 01:41 PM   #4
There was a guy from Ms that ran one of them.I think he worked at Comp?
Richard?
That's probably why it's in the book.
Rule No. 1 ,
Don't build a Stocker just because you have the vehicle. Build the best one for the class you want to run.
For example , my Mustang is only rated one more hp, is 140 ci, and has a turbocharger.
It can't run W though, where the S10 can .Still don't think it's the best W combination.
For your trans question, a turbo 200 3 speed, as light duty as you can make it.
You would have to have an idea of where the peak torque and hp is before you can gear it correctly.
Old 03-01-2009, 04:22 PM   #5
drag55
Thanks for your input. It is greatly appreciated. I thought it might be a more affordable way to get into stock eliminator racing. Thanks Ron
Old 03-18-2009, 01:27 AM   #6
rayfin
Talking Re: 2000 S-10 Stocker
At least you could take a nap on the way to the finish line.
rayfin is offline   Reply With Quote
Old 03-18-2009, 02:06 AM   #7
Rayfin, I hope you're friends with Drag55.
Old 03-18-2009, 07:39 PM   #8
drag55
What do you run Rayfin, if anything?
