Old 03-13-2009, 01:14 AM   #1
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Talking 1968 Camaro 350THM
So my question is...why are you not allowed to run a 350 turbo trans in stock in a small block 68 Camaro. I bought a 295hp stocker motor on this board, drove 7 hours to pick it up to be dissapointed that I can't run it because of the trans rule. My fauly I know, should have read in between the cracks that are in between the cracks in the rule book. So now do I spend $2000 on a new powerglide trans/converter to run the motor or freshen my 330hp crate for half that money and run it again? Heres my beef....check out the links.
http://www.kitcarusa.com/kb.php?aid=108 - scroll down untill you see 350THM
http://www.automobilebestbuys.com/an...s.php?RID=1574
http://www.experiencefestival.com/a/...350/id/5547454
Theres alot more crazy combo's in Stock than a 3 speed behined a 295hp 350...but we won't even start a new 72 page thread.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 03-13-2009, 05:48 AM   #2
bobby
bobby's Avatar
Default Re: 1968 Camaro 350THM
Fot the second link. Seller comments.
This Baby is a THM350 (Turbo-Hydramatics Only available on the SS396 Camaro)!
Stick a 396 in it.
Next time wave all of your fingers at me.
bobby is offline   Reply With Quote
Old 03-15-2009, 11:51 AM   #3
MHoward
Crate Camaro,If you are going to run all IHRA I would freshen the Crate Motor,It is alot easier to make run under the Index,On the flip side the 295/350,with a glide is a very consistent combo,but will not win any heads-up races. I have run this combo for years,wasnt that bad until all the Technology came around for the three speeds now it is a horrible combo,NHRA will not allow a three speed in a small block 67-68 camaro because chevy didnt put a three speed behind the small block until 69.You are allowed to run a 295 hp Motor in a 69 or 70 Camaro @ the same hp rating with a three speed.GOOD LUCK.
MHoward is offline   Reply With Quote
Old 03-15-2009, 01:35 PM   #4
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Stick a 396 in it.
i'd argue that i've NEVER seen a big block with a 350 turbo behind it in an OEM vehicle.
besides, i'me pretty sure th350's didn't enter the scene until 69...in anything.
Old 03-15-2009, 02:21 PM   #5
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Smile Re: 1968 Camaro 350THM
Monte,
Don't be so sure about not being able to win any heads up races.
If NHRA allowed you to run a three speed,how much do you think you would pick up?
See you at Indy.
Old 03-15-2009, 04:14 PM   #6
Bub Whitaker
350's showed up late 68... had large journal rods with 11/32 bolts. still have some at the shop.Opps... dating myself
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
Old 03-15-2009, 06:53 PM   #7
Tom keedle
Tom keedle's Avatar
actually, 350 ENGINES showed up in 67...
350 trannys were 1st built in 69 (model year)
Old 03-15-2009, 07:34 PM   #8
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
True, big blocks would have had the th400, but with the rules the way they are, th350's can be used.
Old 03-15-2009, 07:46 PM   #9
MHoward
Daryl,
I would be able to pick up .18-.20,ask Gary Russell if you dont believe me he has done it for a test,Freddy Burris and I Pitted together for years and he ran a glide at points meets and a 200 MaClay when he needed to go fast and his 200 was always 2 tenths faster.
Old 03-15-2009, 07:54 PM   #10
MHoward
Bub,
You are correct about the Late 68's having a th350,but getting NHRA to acknowlede it is impossible,they allow super stock cars with glides a 3 speed but the glide doesn't slow them down as bad as they do in a low hp. stocker,we need gear.
