Old 04-01-2009, 05:24 PM   #11
Frito
Frito's Avatar
Liked 119 Times in 40 Posts
Default Re: Have question
[quote=Joe Marcinowski;111879]Try IHRA Pure Stock.
Easier and cheaper than Stock, and you do not have to molest the car.
A great place to learn, then step up when your ready.
Good Luck,
Joe[/
Old 04-01-2009, 07:17 PM   #12
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
I agree on the prue stock deal if you live close to an IHRA track. That's the way I got dad started the we built him a "real" stocker. As far as pure stock goes the 87-93 5.0 mustangs are EASY!
Old 04-01-2009, 09:14 PM   #13
Burner
Looks like it's heading that way, although the crate motor class may be easier.
Still working on it. Really don't want to run a late model mustang but i can see were it would be easy.
Really need to sit down and understand the rules, we have a pro am coming to Pinevalley in June I think. My set up the Bracket car for Super street and see what its all about?
Thanks for the info
Phillip
Burner is offline   Reply With Quote
Old 04-02-2009, 10:40 PM   #14
STOCK1278
STOCK1278's Avatar
Thumbs up Re: Have question
Just saw this, not a bad start.
http://www.aatwracing.com/olds.htm
Jason M Silver
NHRA Stock Eliminator - 1278
88 Oldsmobile Cutlass 307/213
STOCK1278 is offline   Reply With Quote
Old 04-03-2009, 06:06 AM   #15
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Nice car.....Could handle GM big block crate engines also If you wanted to go faster. Inexpensive way to get into racing.
Old 04-13-2009, 08:18 PM   #16
Burner
Thanks for all the input, Sorry no reply been busy traveling,
Found a 73 duster, 1 owner very clean has been sitting up for a while, still has the build sheet behind the seat.
It has a slant 6 and a factory 4 speed, been looking at the car for a while and final caught someone home. he is willing to part with it though.
Not really a mopar fan, have always built chevy's and a few fords, but wonder if this car will fit a class that is less demanding?
like the body style, don't know if the 6 would be worth the trouble?
Like to olds that's not a bad price, i sent out some e-mails out about the late model nova, no replys yet, seems like it ran 1.5 over the number,
Anyway still working on it, sounds like the pure-stock may be the way to go. May go with the 68 camaro anyway, at least its sitting in the shop..
Thanks again.
Phillip
Old 04-13-2009, 08:39 PM   #17
RJ
The Duster would be a good choice for pure stock run as a 74 with the 360/904. The engine rules are as NHRA stock eliminator was in the early 80's before it got out of hand. You can take an additional 10 hp off as you would be using the factory 904 trans. Also, the cam duration specs are quite generous, and the combo will easily run way under the index.
RJ is offline   Reply With Quote
Old 04-13-2009, 09:00 PM   #18
Burner
OK, purchase the duster, pull the 6, replace with a 360, got that much, is the 904 the stock 4 speed or an auto(Sorry I know my chevy parts but not a dang thing about mopar).
As stated before The rules are a little hard to understand, what is needed to change year models, just state it to be a 74 or is there badges etc.. to be changed?
Thanks
Phillip
Old 04-13-2009, 09:22 PM   #19
Dave Gantz
Liked 251 Times in 125 Posts
Go hang out at some races. The more the better. Ask questions. See what it's really about before jumping in. Have you read some of the threads on here?
Old 04-13-2009, 09:37 PM   #20
Burner
Making the races, was in houston couple weeks ago. spent most of my time in the sportsman pits, yes have read some of the quotes still learning though. seems like there is a lot of info to swallow. getting some great info though.
