Old 05-29-2009, 11:40 PM   #31
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: Aubrey's 62 409 goes 11.067 in C/S
Aubrey,,,,sell off one of your other "hotrods" and slap a good unit like a Moser 12 bolt under there with the spool/axle/ gear ratio package you want.You can even get them with disc brakes. I had one question I forgot to ask you last weekend,,,are you running a 2 piece driveshaft? I think those cars came that way did'nt they? I'm curious how they make them live under a heavy car with a lot of power and a manual transmission,, and if you have to beef up the carrier bearing.
Good luck,,,I hope to see you again out there somewhere,,,,,,,,Danny Durham
Old 05-30-2009, 12:56 AM   #32
Grant Eldridge
Grant Eldridge's Avatar
Default Re: Aubrey's 62 409 goes 11.067 in C/S
Congratulations, Aubrey, great meeting you at Mission and seeing your car run! I raced 409 Chevys in the '60's when we were lucky to get into the 12's with the track prep and tires of the day. We broke dozens of those old rear ends, as well as the axles, driveshaft centre bearing supports, u-joints, clutch linkages and of course the old Muncie transmissions. With todays tires and traction I can't imagine attempting to use that rear end. We even broke the pinion right out of the carrier on one pass, hanging off the end of the driveshaft with half the casting, the rest still bolted into the car! The chevs were bad for not upgrading the rest of the driveline to handle the bigger motors, this was essentially the same rear end found in six cylinder cars, They bolt right into the early 4 cylinder Novas even! We did improve the situation by heat treating gear sets to soften them, as I recall from 40 years ago they were about Rockwell 62-64 and we drew them down to about 52-54 from ancient memory. That made them wear out faster, but less likely to break. We'd also set the gear pattern on the drive side well towards the inside of the tooth and use as close to zero lash as we dared. The case and carrier deflect substantially and the pattern shifts out on the tooth, so if you start centered you'll move out and break the teeth off on the outside of the ring gear. I recall guys using steel straps machined to fit on the main caps to strengthen them and longer bolts. I even seem to recall some guys brazing up the end of a bolt and threading it in through the side of the case so it would contact the back of the ring gear somehow to help stop the case from spreading, not sure of exactly how this was positioned or if it was effective. The point is exactly as Tony Janes said, it's junk and a waste of your time and money to attempt to keep it in one piece. Even if it were an automatic, it would be highly doubtful that it could be reliable. As others have posted, the 12 bolt should be no problem to rework with suitable mounts, etc and you'll be saving yourself endless problems with the old 10 bolt. Anyway, best of luck! It's a cool ride!
Grant Eldridge
E/SA 6650
Grant Eldridge is offline   Reply With Quote
Old 05-30-2009, 06:48 AM   #33
Alan Nyhus
Liked 799 Times in 236 Posts
Very cool. I bought/sold/traded a lot of 409 cars and parts some years back...love those W motors and the cars.
The rear ends in the 58-64 full size cars aren't as wide as the body style would lead you to think they are....a '67-69 Camaro/Nova or '64-67 Chevelle rear end are perfect replacements in drum-to-drum dimension. I did a 12 bolt swap into a '62 Biscayne some years ago that worked out really slick....used a Camaro 12 bolt and welded the brackets from the original '62 read end onto it. Using the back surface of the 12 bolt (where the cover bolts on) and the the front surface of the '62 rear end (where the 3rd member bolts in) as reference points, it was easy to duplicate the correct geometry of the lower control arms and the upper control arm. The control arms were reinforced and I did some old school stuff on the control arm bushings....sheetrock screws screwed into the bushings (3 per side) to stiffen them up.
For brakes, we used a setup from '65-'70 big car (Impala) to replace the 9" brakes from the Camaro. The housing ends/bearings on the '65-up cars are bigger than the Camaro/Nova/Chevelle rears and the bolt spacing of the backing plates to the flange is also wider. I welded up the backing plate mounting holes, redrilled them to the correct location and made up a small steel spacer ring to take up the clearance between the '65-up backing plate and bearing housing o.d. of the Camaro rear. Worked slick. A disc setup would be the way to do it today, of course.
The two-piece driveshaft was replaced with a one piece unit. The notch where the rear portion of the original 'shaft comes out of the frame tunnel was opened up foward to allow for the greater angle....since the driveshafts pivot point was now at the front u-joint instead of at the carrier bearning in the middle of the tunnel.
Congrats Aubrey on a 'way cool stocker. -Al
Old 05-30-2009, 12:13 PM   #34
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Thank YOU, Grant, Alan...
It's just that easy to give up the old thing !
Here's what I've done:
webbed housing
bearing caps
spool
30 spline
larger outer bearing
ID:	854   Click image for larger version
ID:	855   Click image for larger version
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 05-30-2009, 12:48 PM   #35
treessavoy
Liked 4 Times in 4 Posts
Aubrey,
Back in the day I seem to remember the chevy guy's putting the Olds or Pontiac rear ends in their cars.....don't know if this is a viable option anymore, I'm sure no one makes the gears and parts.
My tri-power '58 Pontiac has one beefy rearend in it!
Jim
Old 05-30-2009, 01:00 PM   #36
bill dedman
Liked 6 Times in 4 Posts
Jim,
I know the '57-up Olds/Pontiac rear ends were really strong units. I just wonder what the diameter is of the ring gear.
Anybody remember that dimension?
Just curious....
Bill
Bill
bill dedman is offline   Reply With Quote
Old 05-30-2009, 01:08 PM   #37
treessavoy
Originally Posted by bill dedman View Post
Jim,
Just curious....
Bill
Bill,
I don't remember either but those rear ends went into a lot of gassers at the time. There are probably gear sets floating around at swap meets.
Jim
Old 05-30-2009, 01:36 PM   #38
Liked 1,880 Times in 422 Posts
Until recently, Strange, and even Mark Williams had stuff for the Olds/Pontiac rear end. However, if you are going to the trouble to change, change to the 12 bolt Chevy. I want to see that car go fast and go rounds. You've suffered enough, for a long time, to make it work, just get a 12 bolt in it and enjoy the car. You've earned it.
Old 05-30-2009, 01:49 PM   #39
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Aubrey's 62 409 goes 11.067 in C/S
Dittos and mega dittos.
Old 05-30-2009, 06:20 PM   #40
Ken Haase
Pretty sure the 'late' Olds/Pontiac's are 9 3/8ths. Not too many ratio's to choose from.
Sure wish you were going to be at Spokane, Aubrey. I'd really like to see your '62 in person. Any chance of that?
Ken Haase is offline   Reply With Quote
