Old 06-03-2009, 02:35 PM   #31
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
Default Re: 8.5" GM Ten Bolt
I'll have to lay underneath it and measure it one day. The problem is that you cant get an 8.5 with a torque arm provision.
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
Old 06-03-2009, 04:21 PM   #32
Mike Savelle
Liked 7 Times in 5 Posts
Wink Re: 8.5" GM Ten Bolt
Lee Before 12bolts where available with mounting brackets for torque arms ,i made a mount to install one in a 3 rd gen Camaro. Had a 350 crate motor in it that ran 10..80s and it never came off but had to tighten the bolts often . Get a good welder and brace it with a U bolt around the snout. Mike
Mike Savelle is offline   Reply With Quote
Old 06-03-2009, 04:48 PM   #33
LNorton
LNorton's Avatar
Mike, Do you have any pictures of this mount?
If so, leernorton@gmail.com
Thanks!
RacerTees.com
Old 06-03-2009, 05:10 PM   #34
Mike Savelle
Lee sorry no pictures but i know Gary Russell had a mount like mine on his fourth gen Camaro when he first built it . I sold my car to Cantucci, if i see him i will take a picture.... MIke
Old 06-03-2009, 08:45 PM   #35
Jesse Knapp
Originally Posted by greg fulk View Post
the 8.2 died in 71...a 71 nova could have either an 82. or 8.5. Tod where you located? I have an 8.5 housing out of a 73 nova that will fit. if ya live close to Ohio I'll take $20 bucks for it...I think I have the axles too.
I have a 71 Nova with a 10 bolt. What do I look for to know if I have the large or small one? Is it maybe ring gear diameter? I knew this a long time ago but can't remember now. My thoughts were to just buy a complete 12 bolt from Strange, but it sounds like the big 10 bolt is plenty stout. Car came with a 307 and a glide. Still has the glide in it. I'm betting it's the small one.
Jesse Knapp 4899 STK, SS
Jesse Knapp is offline   Reply With Quote
Old 06-04-2009, 07:41 AM   #36
Jesse Knapp
I have a horrible memory! I just this morning remember something about the ring gear bolts are larger on the 8.5. Is this how one tells and, if so, what is the size comparison?
Old 06-04-2009, 08:45 AM   #37
skooter
http://www.novaresource.org/axle.htm
skooter is offline   Reply With Quote
Old 06-04-2009, 09:06 AM   #38
bobby
bobby's Avatar
Not sure about the 8.2, but the 8.5 has 7/16 bolts. The 12 bolt has 3/8 bolts.
Dont' worry about the memory, you probably forgot more than most people will ever know.
Next time wave all of your fingers at me.
bobby is offline   Reply With Quote
Old 06-04-2009, 03:53 PM   #39
Jesse Knapp
I am almost sure the ring gear bolts are larger on the 8.5. Thanks for posting the website address.
Old 06-06-2009, 09:22 AM   #40
GTO/GN
GTO/GN's Avatar
I am using the 8.5 in my Grand National . I put Axles with C-clip ele. and a spool in it and using the stock 3.42 gears the car has run 9.64 at 140.11. Leaving off the trans brake at 20 lbs of boost on 28X10.5 Mickey Thompson slicks. It been hanging in there... The picture in my avatar photo is a pretty tipical launch for the car..
GTO/GN is offline   Reply With Quote
