Old 11-15-2008, 04:47 PM   #1
Tod Lane
Tod Lane's Avatar
Liked 2 Times in 2 Posts
Default 8.5" GM Ten Bolt
Can this rear end be built to survive 450 HP in a 3300 lb automatic car, or should I just junk it and spend the extra for a 12 bolt?
Any other advantages to a 12 bolt besides strength?
Tod Lane is offline   Reply With Quote
Old 11-15-2008, 06:55 PM   #2
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Default Re: 8.5" GM Ten Bolt
If you're planning on spool and axles anyway, don't be scared of the ten 8.5 Once the spool and axles are in they don't know what housing is around them! A girdle cover wouldn't be a bad idea for 10 or 12 bolt. The only big downside to the 8.5 is that there isn't as big of a gear selection as the 12 bolt has.
My 2 cents
Old 11-15-2008, 07:15 PM   #3
j gardiner
Liked 55 Times in 29 Posts
I have just finished my eleventh season with my 8.5 rear and i have never had a problem. My car weighs 3350 lbs. and has about 500 hp or so. There are alot of people smarter than me who say a 8.5 is stronger than a 12 bolt. A 8.5 has a thicker ring gear and even though it has less ring gear bolts they are larger 7/16 compared to 3/8. There are alot of Buick gn's running in the 8s with this rear. So by all means you should be able to use this rear with no problems.
j gardiner is offline   Reply With Quote
Old 11-16-2008, 11:37 AM   #4
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
I recently had a 10 bolt and 12 bolt sitting next to one another in the garage. It was interesting to see that the castings were the same overall size. The pinion bearings were very close to the same size. The carrier bearings however on the 12 bolt were larger. One other interesting note, my 10 bolt used 7/16 fasteners where the 12 bolt uses 3/8 bolts to attach the ring gear to the spool.
Which ever option you choose, make sure to have the tubes welded to the casting. I had one twist this year and it was a pain to repair.
Chad
Chad E532 is offline   Reply With Quote
Old 11-16-2008, 02:24 PM   #5
Robert Swartz
Robert Swartz's Avatar
My 2 cents
Interesting stuff here. Looking at the Summit catalogue, they offer a Moser 33 spline spool, no doubt Moser would have the axles as well. They have Richmond 4:88, 5:13, 5:38 and 5:57 gear sets. That's not a terrible selection, work fine for motors running in the 7000 rpm range. If you were running a stick car or a trans brake, might be a different story?
Just running the cost figures, could probably assemble one of these for half what you'd have in a comparable 12 bolt. The 12 bolt would have a better value as a resale point. Sounds like a few of you guys are running these rear ends, be worth looking into.
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
Old 11-16-2008, 06:04 PM   #6
5448
I have been running an 8.5" in my '71 Nova for the past 12 seasons with no problems. Car is 3240 lb with me in it, 500 hp small block, auto, footbrake car. My quickest 60' is 1.39, for reference. I haven't fully welded the tubes to the housing(yet), and I run a stock cover.
I agree with Chad that you should fully weld the tubes to the housing for piece of mind. The girdle cover may be cheap insurance as well. I may even take my own advice and add these upgrades to my 8.5"!
Eric
5448 is offline   Reply With Quote
Old 11-16-2008, 11:56 PM   #7
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Thumbs up Re: 8.5" GM Ten Bolt
My cutlass has an 8.5 stock axles with a best 60' of 1.63 & E.T 12.51 in a 3600 lbs carhttps://www.autoimagery.com/store/cgi-bin/imageFolio.cgi?action=view&link=NHRA_Division_3/2008_Division_3_events/Columbus_-_NHRA_Divisional_-_Jul_2008/Stock&image=0830-09029.jpg&img=12&tt=&tfile=tn_0830-09029.jpg
Old 11-17-2008, 12:05 AM   #8
Tod Lane
Tod Lane's Avatar
Thanks for the info guys, it looks like a usable alternative for what I have in mind, the extra $$ for a 12 bolt could be used elsewhere!
Old 11-17-2008, 12:06 AM   #9
Tod Lane
Tod Lane's Avatar
Eric
Good axles and spool?
Old 11-17-2008, 10:11 AM   #10
5448
Tod,
I just run 28 spline Moser axles with C-clip eliminators and a standard Strange steel spool.
Eric
