Does anyone know if a Pontiac 326 has been raced successfully in Stock Eliminator? I know that Pontiac Firebirds with 400 cubic inch motors have been successful; but what about a 1966 LeMans with a 326 factored at 285 HP?
JR |
#2 | |
Only thing it's got is cam and compression. Compared to the later stuff,.... lousy heads, intake, carb. 2 speed automatic, too.
Liked 6 Times in 4 Posts
I remember a nearly new 1963 Tempet with a 285HP 326 that used to show up with Bucrons and a 3-speed transaxle and run 90 mph pure stock. I don't know his e.t., but the 90 mph sounded pretty impressive to me, for the HP. He beat a lot of people with that car...
But, that was then; this is now...
Bill |
#4 | |
2 barrel only untill 64, |
Sure they did. 280 hp with stick shift. Check the guide.
![]() NHRA guide is wrong. I looked at them new in 63 before going into the service. No 4 speed and no 4 barrel. Bought a Dodge when I got out and never looked back. http://www.conceptcarz.com/vehicle/z...c-Tempest.aspx |
#7 | |
Incidentally, the 63 326 was actually a 336. It had a slightly larger bore than the later 326s.
1964 GTO 2750# 606" IA Pontiac 8.2550@164.17-1/4 1.1981-60" 5.2901@131.97-1/8 |
Mark,
Thanks for the info. Would you say the same for a '66 Pontiac in GTO trim with the 335 HP 389? Same 2-speed transmission, same Carter carb, same valve size (though different heads), more compression and more cam lift??? JR |
#9 | |
You'd have to live with a 1.76 low gear too You could write a letter to 1-800- CRY-NHRA, but I hear that office is boarded up.
