Old 07-27-2009, 12:02 PM   #21
cambria
Default Re: New Camaro ET's
I will run mine wednesday and let you know
BS/A,A/FIA 00 Camaro-
CS/A, B/FIA 94 Camaro .2012 copo 4.0
cambria is offline   Reply With Quote
Old 07-27-2009, 01:06 PM   #22
MikeFicacci
Liked 19 Times in 2 Posts
With both the Camaro and G8 you can leave from idle or 1000 to 1500 rpm. The converter we use is a Vigilante 2800-stall triple-disc lock-up from Precision Industries. The problem isn't getting the car to hook, the problem is the 1/2 shift that spins with just about every tire we put under it. We put the car in manual mode and shift at 5500 instead of 6400 which tends to take care of the problem.
The Camaro is going to be a very quick car with a few modifications. One of the biggest advantages with the 6L80E cars is the L99 engine with variable valve timing technology. The problem we are now having with out 850 horsepower G8 is that no one will let us run 10's at over 140 without a roll bar, jacket, driveshaft loop, etc... Although we will be running it next week.
MikeFicacci is offline   Reply With Quote
Old 07-27-2009, 01:19 PM   #23
GeorgeInNePa
I haven't tried leaving from idle yet, I've been foot-braking it to 2000.
GeorgeInNePa is offline   Reply With Quote
Old 07-27-2009, 01:26 PM   #24
Sean Haning
Sean Haning's Avatar
Send a message via AIM to Sean Haning
Wink Re: New Camaro ET's
Every track will let you do it once, lol. Some twice if you tell them the first time was an accident.
Hired gun w/o gun.
Sean Haning is offline   Reply With Quote
Old 07-29-2009, 10:08 AM   #25
jarn05
[QUOTE=keith ohanesian;131432]
Originally Posted by jimi View Post
This is funny. "that's pathetic".... Jimi my tow vehicle goes 13.50 with two people in it. Oh that's @ 8000 pounds... Its almost as fast as the car its pulling.
hey **** and balls! how have you been? i saw you at lebanon valley did not have the time to stop by, you probably have three times as much invested into your truck just in the turbo and head studs then you have spent on the old camaro!!!!!! hahaha, stop by some time to shoot the *****.
jarn05 is offline   Reply With Quote
