Old 08-13-2009, 05:25 PM   #1
Lyn Smith
Liked 997 Times in 201 Posts
Question Aluminum master cylinder?
When going to the after market front disc brakes is there a all aluminum master cylinder that will work instead of the plastic aluminum one that the companies sell?If so what does it come on.thanks
Old 08-14-2009, 07:16 AM   #2
Lyn Smith
Question Re: Aluminum master cylinder?
Are there any regular automotive all aluminum ones that will work ok?
Old 08-14-2009, 09:53 AM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Aluminum master cylinder?
OEM Chrysler applications are popular that have the aluminum body and plastic resevoir.
I have a OEM manual disc/drum application from a late '70's Aspen/Volare on my OEM manual disc/drum Dart Sport. But I was considering doing to a larger truck version if I switch to aftermarket front discs.
I don't have any part #'s handy because I'm at work.
LOCOMOTION Racing
Old 08-14-2009, 11:10 AM   #4
FED 387
Liked 333 Times in 180 Posts
Default Re: Aluminum master cylinder?
--Lyn -----many of the late model GM cars specifically the corvettes utilize an all aluminum master cylinder and have a metal(steel) cap held in place with the old style snap ring setup--- they are very light only about 5 pounds each--- do not know how much trouble it would be to graft it onto your car tho---probably just hafta fabricate a plate to bolt onto your firewall and then make the appropriate rod to go from the B pedal to the cylinder--- should not be to difficult to do----- Comp 387
Old 08-14-2009, 11:52 AM   #5
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Lyn, 1979 Dodge PU 2wd is what's on mine. Aluminum body w/plastic resevoir. As long as it hasnt changed part #'s, it looks and works just like the Lamb high$$$ unit.....
Wade O
Old 08-15-2009, 06:29 AM   #6
bsa633
Banned
Wade O
Just dont forget to secure the "PushRod" the way Lamb has..been a couple of incidents ..Biondo..Woodro(i think) etc.
bsa633 is offline   Reply With Quote
Old 08-20-2009, 01:10 PM   #7
Dave Casey
Liked 797 Times in 165 Posts
mid early 80's S10 master with manual brakes. I have bought 3 of them and never used a proportioning valve. When you buy one, sometimes they come thru steel instead of aluminum, so check the box before you leave the store. Never had a leak issue.
Dave
Dave Casey 1330 STK
Old 08-20-2009, 04:04 PM   #8
Lyn Smith
thanks guys for all the info.
Old 08-21-2009, 07:00 AM   #9
Greg Hill
Liked 279 Times in 68 Posts
Lynn, I use a strange MC with no problems. It's been on my car for about 10 years. I think it's a 1" bore. Some of the mid 70's corvette MC will work with just front discs.
Greg
Greg Hill 4171 STK
Old 08-21-2009, 05:02 PM   #10
Tod Lane
Tod Lane's Avatar
Liked 2 Times in 2 Posts
Dave
Disc/drum combo?
Tod Lane
Swartz & Lane 66 Nova
Swartz & Lane 79 H/CM Trans Am
Tod Lane is offline   Reply With Quote
