Old 08-21-2009, 07:03 PM   #11
Dave Casey
Liked 804 Times in 168 Posts
Default Re: Aluminum master cylinder?
Yes, the s10 only comes that way I think, and my race cars are disc/drum also.
Dave
Dave Casey 1330 STK
Old 03-14-2010, 06:21 PM   #12
Tod Lane
Tod Lane's Avatar
Liked 2 Times in 2 Posts
Originally Posted by Tod Lane View Post
Disc/drum combo?
Ok, we have changed direction and will be going 4 wheel disc.... Would this M/C still work?
Recomendations on bore diameter if I bought an aftermarket?
Tod Lane
Swartz & Lane 66 Nova
Swartz & Lane 79 H/CM Trans Am
Tod Lane is offline   Reply With Quote
Old 03-14-2010, 10:06 PM   #13
rawhide
Liked 7 Times in 5 Posts
Originally Posted by Lyn Smith View Post
When going to the after market front disc brakes is there a all aluminum master cylinder that will work instead of the plastic aluminum one that the companies sell?If so what does it come on.thanks
Lyn,
There is a new Ford master cylinder on eBay that is aluminum with a steel cap. The eBay item number is 270360589638.
Rawhide
rawhide is offline   Reply With Quote
Old 03-15-2010, 11:29 AM   #14
Dave1695
Liked 15 Times in 11 Posts
Lyn: Stainless Steel Brake Coporation (ssbrakes.com) has an aluminum master cylinder the looks like the cast iron Corvette version (their part number 0476) one inch bore for manual disc brakes and only weights four pounds. You can order them from Summit or Jeg's also!
Dave1695 is offline   Reply With Quote
Old 03-16-2010, 07:12 AM   #15
sg1586
You can also look here...Some good info
http://www.dragstuff.com/techarticle...sterCylPN.html
sg1586 is offline   Reply With Quote
Old 03-16-2010, 07:11 PM   #16
rseibenick
Liked 20 Times in 7 Posts
Anyone know where I can get a new brake rod that goes into the back of the master cylinder. I have a 24 MM bore size dodge aluminum master cyclinder. Thanks.
rseibenick is offline   Reply With Quote
Old 03-16-2010, 08:44 PM   #17
skj283
i just went through all this. a late 70's early 80's pickup is 1 1/8 bore, mid 80's diplomat is 1 1/16, and mid 80's daytona is 24 mm which is under an inch. BUT i put one on my car and dont like it and am gonna go to the diplomat. also most of the new mastercylinders are cast iron replacements but the rebuilds which are like 15 bucks are aluminum. hope it helps.
skj283 is offline   Reply With Quote
Old 08-07-2010, 11:44 PM   #18
cad
cad's Avatar
Liked 93 Times in 52 Posts
This has the info for the Mopar M/Cs:
Old 08-09-2010, 11:41 AM   #19
cad
cad's Avatar
Sorry SG1586...u beat me to it.
