Old 09-05-2009, 07:20 AM   #31
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Default Re: CJ OUT at Indy!!
Originally Posted by Bill Harris View Post
Did they pull a rod a piston out of these engines? If not, how can they accurately measure the CCs of a dish in a piston that is sitting at a 45 degree angle in the block?
It can be done....I did it all the time. I checked the winner of the quick 32 S/S at the US Class Nationals several years ago and my measurement was "Dead on" the manufacurer spec. and matched the engine guide in the car at a 45 degree angle while leaning over the fender. If I remember correctly it was Randy Manns car. It was an Olds engine in a Camaro or Firebird (cant remember which) SS/GT car. It even surprised him.
Old 09-05-2009, 07:34 AM   #32
Jeremy
RJ you said your burette checked the same as NHRA Tech's burette. The NHRA Tech's burrette's (2) I checked from our Division did not check against each other as I said there was a .8 cc differance.
I tried to call you when I was in Pipe Creek, I have the wrong phone number.
Jerry
Jeremy is offline   Reply With Quote
Old 09-05-2009, 07:51 AM   #33
X-TECH MAN
Banned
The given tolerance for a burette is 1%. On a 100 C.C burette that is 1.0 (one point zero) C.C.s. Reason alone to allow some wiggle room when milling your heads. Not only the burette is involved but the medium usuallly used is alcahol and is tempature sensitive. A hot cyl. head will not check the same as a head at room temp. The alcahol will expand when the head is hot and give you a smaller reading. Some go so far as putting the head into a cooler full of ice to bring down the temp of the head. 1/2 or even a full C.C over the spec. will not slow down the car. The engine will never know it.
Old 09-05-2009, 08:03 AM   #34
Pete Beau
Pete Beau's Avatar
Liked 31 Times in 12 Posts
Jerry
So, if we allow 10% G R&R the minimum tolerance that that system could measure would be 8 cc's!! Now that may seem ridiculous but that’s the results of the calculations. So how much error do you want to allow in the system? If the tech. stated that your combustion chamber was .5 cc small then that measurement was within the error of the two gages.
Also keep in mind some features are more difficult to measure than others. The most difficult are visual attributes or specifications. One persons course finish is another’s fine. A color (one of the most difficult) may look light blue to one person and medium blue to another.
The budget for the measuring system plays a big role. Like anything else, you get what you pay for.
Pete Beau is offline   Reply With Quote
Old 09-05-2009, 08:20 AM   #35
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
I was reading post and going to make basically same statement as you Terry.It does'nt matter what your
burett or mic's or caliper shows the tech man goes by their tools reading it's our responsibilty to leave
room in our measurements for difference in gauges,just like lbs per cubic inch classes it's your responsibility to claim correct cubic inches.I had customer truck pulling406'' limit so everyone built400sbc
30 over he got pumped 406.7 would'nt pass so I had to destroked cranks to 3.735 stroke deck block.007
rebalance actaully ran better then because crank had stroke&index equalized then.
I heard of some Dodges that got bounced at Indy several years ago few minutes later truck owner supposedly came up on golf cart w/ the updated specs that had been faxed to him from mopar so they were legal.Has anyone else heard that story before?
Mike Taylor 3601
Old 09-05-2009, 08:27 AM   #36
Chad Rhodes
Mike Taylor 3601
I would have thought that if it was a specs mistake that ford would have gotten them reinstated by this morning. It may have cost them a few GT500's for Compton's kids or something but I figured it would have been done. I would think that a manufacturer advertising and selling a "stock eliminator legal" car that didn't pass tech would be opening the door for a ice class action lawsuit. If they don't get the spec changed, then all of these motors have to be taken apart to check for legality. If I were NHRA, I would not change the spec without a reevaluation of the HP rating
Chad Rhodes 2113 I/SA
Old 09-05-2009, 08:58 AM   #37
X-TECH MAN
Banned
Mike Taylor 3601
The problem with a P&G pump is its not that accurate (dead on). Cranking speed of the starter/voltage of the battery and the cam shaft over lap has a little to do with the reading not to mention the temp allowance used. Normally if one is used correctly and all othe varibles are there (cranking speed, etc.) the P&G pump will show a little UNDER the actual cubic inches. It all depends on the person using the pump and his/her experience. Not all P&G pumps measure the same either.
Old 09-05-2009, 11:13 AM   #38
Pete Beau
Pete Beau's Avatar
When a written quality assurance policy is not specified there is a huge gray area for interpretation. The end result can be good parts that are rejected or bad parts that are accepted. Sound familiar? This is why written quality procedures are developed and issued to all companies and/ or people that have to conform to them.
Old 09-05-2009, 11:47 AM   #39
stefan callender
stefan callender's Avatar
Liked 2 Times in 2 Posts
How does anyone know If these motors were opened up and played with??
Old 09-05-2009, 12:02 PM   #40
Chad Rhodes
exactly why NHRA should not just change the spec with a stroke of the pen at Ford's behest
