Old 09-22-2009, 10:50 PM   #11
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Default Re: Heads-Up Runs
Originally Posted by JrRacer2033 View Post
So my next question then, when would you people classify an acceptable time to run it flat out? Indy Class and thats it?
JIm is right, mostly. Every run (heads-up runs, anyway) should be flat out, to me. But, if I'm in a heads-up with someone, and know that my car can run -1.15 (or more) and am behind with no chance to catch my opponent, I, and most anyone, is going to lift, try and save the HP factor for my combo, and hope my opponent does run fast enough to get hit. I, and 90+% of the other racers out there, are NOT going to take a HP hit AND lose the race. It's like losing twice in one race.
Old 09-22-2009, 10:56 PM   #12
Mike Carr
Mike Carr's Avatar
I should add, to further answer your question, that most Class racers are not flat-out in Eliminations. The car is tuned back, in "bracket mode", to be more consistant. The only time a car is tuned up to go fast is Class Eliminations (any race, but Indy especially), heads-up runs in the Eliminator, Record Runs, or if they want to qualify near the top to get a favorable spot on the ladder. A racer once wrote that their car would become "evil" at time when set up on "kill" (huge wheelies, etc), so most tune them back for the shoe-polish part of the Eliminator. Example, having an A/SA that would go 10.40's in "bracket mode", and run 10.0's in all-out mode. The car would tend to repeat more consistantly running 10.40's, hence that reason.
Old 09-22-2009, 11:02 PM   #13
JrRacer2033
Thank you Mike for the clarification! I've got one situation I would like to hear your thoughts on. So lets say you have someone covered (or believe to have someone covered), you play it safe on the tree and get "treed" by .05, would you risk running -1.15 knowing you would receive HP to get back around them to get the round win or just dump and race another weekend?
JrRacer2033 is offline   Reply With Quote
Old 09-22-2009, 11:14 PM   #14
Mike Carr
Mike Carr's Avatar
Yeah, I probably would. -1.15 won't get you hurt *too* bad. The rule was you had to run -1.15 twice (at different Nat'l events), or you, plus one other racer with your combo (at that or another Nat'l) both had to run -1.15 to triggger an evaluation, and if that particular combo averaged more than one second under during that half of the season (all data goes into first or second half of the season), it would then get HP. Which favors a combination with many cars running it ('67-'69 Camaros with a 396 or 350, '80 something 305 Camaros, for example). There could be two slow cars for every fast one, and the combination would not average a second under, and be safe from getting hit with horsepower. A one of a kind or rare combo, like those I have raced, where there are few or no one to bring the average down, could get hit with HP more easily). The rules were changed slightly for this season, and one racer earned HP by making two runs of more than -1.15 at the same Nat'l. He was the only racer with that combo, at the only Nat'l he ran all year, and received HP, so the rules may have changed. However, if a racer runs more than -1.40 at ANY race (Nat'l, Divisional, Nat'l Open, during qualifying, Class or Eliminator), they get automatic HP the Monday after the race, and more then they would if the combination averaged, say, -1.18 for that particular half of the year. So with that long, complex explanation, YES, I would run -1.15 and take the win and take the chance of maybe getting hit, as long as I got the Wally at the end of the day. If I knew I was going to go -1.20 on that run and STILL NOT WIN, I would lift and live to fight another day.
Old 09-23-2009, 01:29 AM   #15
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Jim Rountree
So your telling me that when there is class run off''s and theres 9 cars and you know that your in the middle of the pack you run wide open in the first round of class even though you KNOW you have the guy covered, lets say by 3 tenths? Why? Why would you show the other guys in your class what you have? SO they can go back and find more ET? Speak softly and carry a big stick is what I was taught and by the looks of how this post is going everyone else agrees. Im always bagging 1 1/2 to 2 tenths when I bracket race and when its heads up time...throw a tunup in and go. But I guess for the purists in the class thats a nono. Those same guys dial everything tight and run it out the door every time when they are bracket racing....never scrub the brakes, never burp the throttle. Trapped in the days when there was 29 SS/L cars to run against and when Christ was a cowboy running the Crondek Timing equipment. 5 years ago in Norwalk Ohio at a IHRA National there was only going to be 2 GT/DA cars racing as of thursday night...friday while we were in the lanes making the first time run 2 more pulled in. We dumped at the 1000 and scrubbd the brakes to a 10.40. The two guys that pulled in late grabbed a qualifying sheet, seen that we were the slowest and never Radial'd or tuned up the cars. Guess what...they were both out in the first round of class because of that, They had all the GT/DA cars covered by a tenth or more easy with a tuneup and tire change. So is it smart to lift....?
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 09-23-2009, 06:51 AM   #16
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Mikey, Mikey, Mikey
I guess that you missed the NHRA change regarding the setting of AHFS triggers for 2009.
NHRA omitted from the AHFS the statement that is posted on their web-site in the Competition Section "Only the quickest run of each event is recorded for each competitor"
Get killer air at 1 (one) National Event at sea level, run 2 (two) runs that are -1.15 or quicker under and you have instant trigger.
I guess that NHRA figured that the best way to keep the Stock & Super Stock racers informed of updates to the system was by omitting certain words to completely change the way that the AHFS is operated.
In my opinion that is a perversion of the process.
What ever happened to full disclosure and a list posted on the NHRA web-site of the year to year changes to the AHFS???
It just makes me feel that the NHRA is our adversary and not our partner, with always trying to get over on us.
Kind of gives you that warm fuzzy feeling when you hear "I'm from the NHRA and I'm here to help you"
But I suggest that if you hear that, look over your shoulder and don't bend over.
Bob
Disclaimer:
NHRA has many fine and upstanding employees of high moral fiber but these are not the people who have established the punitive policies that we have to deal with. Thanks to ALL of the dedicated NHRA employees who against tremendous odds attempt to improve the Drag Racing experience and you know who you are.
Bob Mulry 7516 STK
A & M Motorsports
Old 09-23-2009, 10:05 AM   #17
Mike Carr
Mike Carr's Avatar
Hi Bob. Yeah, I knew they changed something this year, that's why I stated about the car that ran one Nat'l all this year and got hit. It was a V/SA Mopar at Topeka. Qualified #1, and got hit from that race's data only, which was never like that before. I remember the uproar on this forum in late July after several combos got hit. I also remember reading something about the process changing based on how many cars were involved in the trigger process, in a sliding scale format of how much HP and/or how many cars in the date accumulation will be dished out, but I can't find it now. I agree, if there is a system in place, regardless WHAT it is (AHFS, Grade Points, etc), it should be PUBLISHED, so everyone can see in black and white what the rules are. Hard to play by the rules when one doesn't know what they are. Hope things are well out in California.
Old 09-23-2009, 05:23 PM   #18
keith ohanesian
Anthony that was GREAT!! Buff Daddy for d1 director!
No prep is king
keith ohanesian is offline   Reply With Quote
Old 09-23-2009, 05:40 PM   #19
AC
AC's Avatar
Liked 66 Times in 23 Posts
Thanks Keith, figured some humor could do us all good. See you at Atco!
AC is offline   Reply With Quote
Old 09-23-2009, 07:01 PM   #20
Paul Wong
Liked 419 Times in 85 Posts
Anthony that is definitely the best response I have seen in quite a while.
Paul Wong is offline   Reply With Quote
