Old 09-22-2009, 11:22 PM   #41
Phillip marvetz
Phillip marvetz's Avatar
Default Re: New rules for 2010?
Ed and Phil, you guys need to learn how to use the QUOTE function.
You got me there little fella
Old 09-22-2009, 11:24 PM   #42
Sean Kennedy
Sean Kennedy's Avatar
Send a message via AIM to Sean Kennedy
Check your PM's, bud.
2002 Division 6 High School Champion
2007 Division 6 Pro Champion
2007 Division 6 National Open Series Stock/Super Stock Champion
Sean Kennedy is offline   Reply With Quote
Old 09-23-2009, 04:24 AM   #43
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Talking Re: New rules for 2010?
Going back to using class winners ONLY and inspect each one in teardown (let the GOOD tech guys do their jobs) for the eliminator would cure all this BS of shutting off at 1000 ft. It would also make the AHFS system work like it should especially if the trigger was brought down to .8 under. Get rid of that farthest under qualifyer and a lot of the bogus and high dollar stuff will start to go away. Thats the way it was done for years until the slow guys whined. If you didnt win class you got to watch on Sunday.
Old 09-23-2009, 05:10 AM   #44
randy wilson
Liked 22 Times in 22 Posts
it does not matter if they raise the index 2 seconds or lower it 5 seconds, it is still just a bracket race. and if you run someone in your exact class, and run 3 seconds under or 5 seconds over the car with the power wins. i love superstock, but it has lost the mystique. we have no real fan base like they had in the 70s.
don,t have one
Old 09-23-2009, 05:49 AM   #45
Jim Bailey
Liked 584 Times in 94 Posts
Thumbs down Re: New rules for 2010?
Gump, I don't have a problem with any of the new cars. As long as the car can be purchased at the dealer, titled, and legally driven home. Then and only then should the car be eligible to be factored and compete as a Stocker. Stevie Wonder can tell the difference between a Drag Pac Challenger and a Showroom Challenger, or a New Showroom Mustang and a New Cobra Jet. I'm talking about "Purpose Built Factory Racecars". They are Superstockers.. period.. end. If you're gonna let them in stock, give them their own class or limit them to AA. I'll take my lumps (already have) and hope that the AHFS works, but wait for the whinning when the New Challenger starts showing up with the other "approved" engine combos and it infiltrates the lower classes....JB
Jim Bailey is offline   Reply With Quote
Old 09-23-2009, 08:10 AM   #46
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Jim is right on they are SS cars. The drag pak cars have the rear moved up 1/2 inch just like the showroom cars,,,,,,NOT, so they must be SS not to mention the intakes and alum oil pans OH I said not to mention that. Stock my a..
Bob Pagano A/SA
Old 09-23-2009, 08:46 AM   #47
Casey Miles
Liked 508 Times in 92 Posts
I know a way to factor all the cars, make them use the stock valve spring pressures and you'll see them all slow down. No need to refactor anyone engine, it'll be done on it's own.
Casey Miles
248H
Old 09-23-2009, 09:53 AM   #48
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
It looked like there were going to be more G and H cars, so I can F. I'm so far down the latter it's not like it makes a difference whether I run .1 under or .30 under. So mathematical odds of getting a heads up would be less.
Which reminds me of another suggestion I've made before: Each class should have a minimum AND maximum weight. If you're running heavy enough to run the next class, then you should be required to run that class. This is actually born out by the rulebook labeling classes as 10.00 - 10.49, 10.50 - 10.99, etc... NOT 10.00 and up, 10.50 and up, etc.
Consider:
- Min & Max weights
- combined classes (1.0 weight breaks, sticks & autos, or both)
Results in:
- cars no longer running 200lbs heavy
- more heads-up runs
- cars will quickly factor themselves to realistic numbers
- guys can still get started in Stock relatively easily with the "soft" indexes, but are incentivized to make their cars faster.
In all fairness, again, I'm not campaigning for these things... just academic discussion. Doesn't bother me either way if they adopt these things or not. It *would* bother me if they dropped all the indexes .50, as it effectively legislates cars out that are not hurting anything (In fact, quite the opposite... easy pickin's, right?)
Old 09-23-2009, 10:54 AM   #49
Billy Nees
Michael, as a point in fact, some of the racers that were in "teardown" this past weekend at Z-Max were asked how much ballast they were carrying and where it was located. They were then given a good looking over. Fact finding mission?
Billy Nees 1188 STK, SS
Old 09-23-2009, 11:08 AM   #50
Dick Butler
Liked 32 Times in 19 Posts
One year of No Break out Eliminations at National Events would Make for fast correction of HP factors when combined with a 1.00 under Monday Trigger. THIS WOULD FIX THE WEAK HP CARS>
PAY BIGGER money for eliminator to make it worth the work to run and win also.
