#31 | |
Jeff, if you were to have, say, a '64 426 Max Wedge. 415 rated NHRA. If you run -1.40 under (9.900 or quicker in A/SA), a combination gets hit 3.25%, or 14 HP, so you're now at 429. You'd have to carry an extra 112 pounds. All 426/415 Max Wedge racers receive this penalty. And yes, it can change the classification of the vehicle. As an example, when the '93-97 GM F-bodies came out, they were rated at 275 and were in, I believe H/SA in 1995. They are now rated over 340 (I forget the actual number) and can run up to B and C/SA. Hope this helps.
Mike Carr, Tri-State S/SS Association President Looking for 2015 S/SS Race Sponsors Contact me if interested buffdaddy_1302@hotmail.com (724) 510-5912 |
#32 |
That does make more sense, so it's all about weight. I guess you would have to get creative in how you add that much to the car, since you can only have 100lbs. of ballast. Does 14HP really = 112lbs? That should be about 1/10th of a second too.
#33 |
Liked 174 Times in 39 Posts
It depends on the class. A/SA is an 8 lbs per cubic inch class, and 14x8= 112 lbs. AA/SA is 7.5 lbs/in and it goes down in half lb increments for the most part.
#34 |
#35 | |
Here is the link: http://www.nhra.com/competition/classification.aspx |
#36 | |
#37 |
No, 15.01 is the factor that determines what class your car falls in. Say the rated horsepower was 250 and the shipping weight was 3753, this would give a factor of 15.01. O/SA is the natural class for car with factors of 15.00-15.99. This means that you could in N/SA, O/SA, or P/SA at their appropriate weight breaks. This car would have to weigh (15x250) + 170= 3920 lbs in O/SA. If the horsepower rating were changed to 255, the factor would be 3753 (shipping weight) divided by 255 (the new horsepower rating) which is 14.72. This would make it a natural N/SA car and it could run M/SA through O/SA at the appropriate weights.
#38 |
Any car that goes more than -1.40 under the Index, has to add 3.25% to the at-the-time HP rating. Max Wedge 426/415 = 415 x .0325 = 13.4875. All numbers are rounded up, so it's 14 HP, and your car is a now a 426/429.
#39 |
I think I am starting to see the light. So at 1.15 under raises eyebrows, and 1.40 is automatic horsepower? Is it a one time offense, and you suffer the consequences, or do you have to back it up like a national record?
#40 |
Jeff, check some of my previous posts about the -1.15. The rules may have been changed from what I wrote. It used to be you had to run -1.15 at two different events, or you plus another with your combination had to each go -1.15 at that, or any event, in either the first or second half of the season, to trigger a review. Data (from Final Qualifying sheets at National Events only) was only accumulated for each half. So if you went -1.20 at the Winter Nat'ls and -1.20 at the World Finals, you were safe. If you were to go -1.20 at the Winters, and someone else with your combo also ran -1.20 at the Winters (or if you at the Winters and another racer with your combo at the Gators), the combo was "flagged". Then all runs by that combo were evaluated, and if that combo averaged one second under, it received HP on a sliding scale. However, this year, a V/SA combo qualified #1, and ran more than -1.15 twice at Topeka. It was the only Nat'l he, or anyone else with that combo, competed, and he got HP. There was quite an uproar on here over a few combinations that received HP. Any run, at any time, at any NHRA event of more than -1.40 causes that combo to receive a 3.25% HP penalty effective the Monday following said event (or an Index adjustment for SS/AM, SS/AS, etc). The whole Horsepower System is explained online, but I believe the rules were changed since it was written, and apparently, there was not a publicly mentioned notice of any change(s). http://www.nhra.com/competition/automatichp.aspx
