Old 10-23-2009, 01:03 PM   #11
junior barns
Liked 20 Times in 14 Posts
Default Re: TH-350, how long should the shift take.
I have a dumb ?
the rpm spikes to 6000 then looks to turn down to 5700 before going up. What does this mean if anything??
junior barns is offline   Reply With Quote
Old 10-23-2009, 01:06 PM   #12
Bill Grubbs
Liked 564 Times in 66 Posts
Chad,
PM
Bill
Bill Grubbs is offline   Reply With Quote
Old 10-23-2009, 01:34 PM   #13
buzzinhalfdozen
Liked 11 Times in 8 Posts
Chad, based on what I'm seeing on your graph the shifting looks fine compared to what I've seen on others and my own after some tweaks. Looks like you have a 6100-6200 converter based on the dropback, also looks like you're over reving it a bit if the white line is the accelerometer you can see it starting to drop off rapidly just prior to the shift. I'm sure there are guys here with alot more experience than me on this but it looks pretty good to me. Joe
Joe Buchanan SS/BX 3117
Old 10-23-2009, 01:36 PM   #14
Chad Rhodes
yes, on that pass i most definitely overwound 1st on that pass
Chad Rhodes 2113 I/SA
Old 10-23-2009, 01:43 PM   #15
buzzinhalfdozen
On my set up when I was having trouble I would see a sharp dip on my Accel. trace, I could also actually "hear" it making the shift, it definately was not a clean change in ratio. Looks like you have that thing hooked up. Joe
Old 10-23-2009, 02:04 PM   #16
Chad Rhodes
Originally Posted by Bill Grubbs View Post
Chad,
PM
Bill
PM replied
