Old 11-14-2009, 09:54 PM   #21
Bruce Fulper
Liked 54 Times in 33 Posts
Default Re: Single wheelie bar
Bob Bales invented this back in the 80's. Go to Autoimagery.com and look at the massive bar he uses.
Bruce Fulper is offline   Reply With Quote
Old 11-15-2009, 05:09 AM   #22
Adger Smith
Liked 880 Times in 311 Posts
Lighter.. How much does unsprung weight hurt your shock/spring setup?
Adger Smith (Former SS)
Old 11-15-2009, 05:58 PM   #23
Troy Henderson
Troy Henderson's Avatar
Liked 130 Times in 42 Posts
Here's mine in action.
Ken's is simplier in that it bolts directly to the housing. Mine has the lower bar going to brackets on the housing and the top is tied into my bolt on anti-roll. You can easily bolt to the top or the frame rails if you don't wan't to mess with an anitroll. The advantage with mine is it doesn't pivot with the axle, it stays stationary when the car launches. This keeps the rear tires from unloading. If you watch the wheel in my video it barely moves when I drop the clutch. I have been wanting to build a bunch of them but I just haven't had the time so if any wants to learn more shoot me an email and I'd be happy to fill you in.
Would you believe I had to use a 560lb-in spring to make it work the was I liked it
Troy Henderson
Henderson Race Shop LLC 816-520-5389
www.hendersonraceshop.com
Troy Henderson is offline   Reply With Quote
Old 11-16-2009, 07:56 PM   #24
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
I have one of Troys wheelie bars on my car. No brainer to install and made the car way more consistant. Pretty easy to set up as well. Heres a pic of it in action...cant even tell its there when im driving its so smooth.
ID:	1793   Click image for larger version
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
