Old 02-25-2010, 07:56 AM   #11
Billy Nees
Default Re: Help with U/SA
It doesn't have to be a feedback carb. You just need a 1.21 venturi dual jet. Basically ,it's the front half of an 800 Q jet.
You guys DO know ,you're going to have to put a custom 12 bolt in that car, in order to be able to play with the gears?
I'd figure out a baseline on the ratio, and then ,when you go lower and don't pick up 60' but lose MPH, go back to where you were!
BTW, if you're not too deep into that car, I'd back right out of it ,and into a 78 Camaro 305 2 GC 2bbl car .
You could use the 8.5 rear that comes in them.
If you're looking to build a "dime rocket" then I would absolutely agree with Mark. There's no cheap way to put a rear in a Monte Carlo that will give you any gear selections. I think that both combos have about the same overall potential.
The only other thing to consider (other than having a car vs. finding and buying a car) would be the difference in weight between the two. The Monte Carlo has to weigh only 3170 to make U/SA while the Camaro has to weigh 3770. I like towing light cars.
Billy Nees 1188 STK, SS
Old 02-25-2010, 11:44 AM   #12
Valid point, Billy.
I actually didn't realize the hp rating on the 267 was that low.
It might be worth a shot for someone willing to spend the money on the rear end.
Maybe some math major could analyze the specs and give us a hp and torque potential.?
Old 02-25-2010, 04:42 PM   #13
mtkawboy
Liked 54 Times in 18 Posts
Keep it coming guys, I love the modern low class tech lessons. Must be from my old P/S junior stock days & old age.
mtkawboy is offline   Reply With Quote
Old 02-25-2010, 05:13 PM   #14
Billy Nees
Valid point, Billy.
It wouldn't be too expensive if he could find a GN rear!
Old 02-25-2010, 07:43 PM   #15
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
I would not put 1 cent into that combo but I have a brand new set of .060 cast pistons in the box for FREE. It's the carb! The 305 2G is a possible and by the way I have one for sale HAHA just needs the motor. I have not had much luck with any two barrel.
Daran Summerton is offline   Reply With Quote
Old 02-25-2010, 09:11 PM   #16
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: Help with U/SA
We're putting a Moser 12 bolt in the car. I realize it's overkill for a U car but I have a few ring and pinions of various ratio's as spares so we can see which one will work the best when we get it running. we're starting out with a 5.13 and go from there.
Bill Bogues is offline   Reply With Quote
Old 02-25-2010, 09:29 PM   #17
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
A side note on the g body rearend problem, it's quite easy to make a 8.5 from a 78 up caprice fit, needs to be narrowed, and you need to make a set of upper arms similar to a body swap arms but it's cheap and easy if you can fabricate.
Old 02-25-2010, 10:46 PM   #18
Jack McCarthy
Liked 477 Times in 117 Posts
best of luck...
...dig up steve & bear tarrance for carb help, he's the only one ever made the 1/2 q-jet work, and stay away from bob shaw & that caddy, he can be pretty depressing
oh yeah start drinking beer immediatley, and welcome to U/SA the class that has fun !
captain jack
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 02-26-2010, 09:29 PM   #19
joe huestis
Liked 409 Times in 113 Posts
While on the topic of U/SA cars, there was an Olds Cutlass I remember About !0 - 12 Yrs. ago with a 260 V8 combo that was killer in that class. As I recall NHRA outlawed this combo. Can anyone give the details, just wondering... I always thought another good combo for this class would be a '75 Chevy Nova with the 262 - 2bbl. V8. What do you think Billy ?
Joe Huestis
"Annie's Song" L/SA 9724
Wake Forest, N.C.
Old 02-27-2010, 04:18 AM   #20
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
I think 260 w/4bbl. was misprint or mistake? wasn't that Bob Shaw with that combo.I've got one of those 267combo's my brother abandoned I thought about using was starting to show alot of potential and he quit the automatic only makes me lose interest.
Mike Taylor 3601
