#11 | |
Im going to try to find a better bolt for these tommorow, you are right they are ARP 2000's I was going to check A1 and a couple others. These torque spec is 63 lbs ? Pistons, well Im waiting on someone who frequents here to get on of the spec DP pistons to someone for the 5.7 the 6.1 is already in process ..... ahem ![]() I will say the first motor failed from a welded bearing and took a fastner loss, the rod took a good hit at 7k and well, it didnt break, it took a 30degree bend but held, THAT from a Scat rod I was actually suprised at, this one Ill have to look closer , if its a fastner issue, thats a lot easier to resolve FAST (Im not scat fan but that comes from years of VW friends and really nothing more than a bad association in my mind) I will say the Scat rod machine work and consistency is very spot on, suprisingly so. Others have found the same thing........so maybe just some good bolts, or better bolts I should say. Thanks, a good point from both.....
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59) |
#12 | |
That was Grubbs suggestion 5 minutes after we all saw it turn into a 13 quart oil sprinkler.
Burnout limiter is now in place. ![]() Also we have no braking from the trans because of the valve body, and well so it was no load free Bolts..... I am curious how this failed across the other rod as well, 2 on seperate journals same bank (drivers) makes me think it was the freespin. Hard to know until I tear it apart, for that I need, the car, for that I need my DAMM trailer fixed......wrong axle in ....BAH. Im CLOSE to saying screw it and buy a new trailer......very very close.... Quote:
#13 |
Liked 544 Times in 213 Posts
Whatever rod bolt you use you have to really be carefull how you tighten the bolts and what lube you use. I once had a rod bolt failure on a Crower billet stroker rod and it was definately from improper tightening of the rod bolts. I pulled a piston out of an engine I built in a friends car. Working conditions were very poor and when I put it back together I did not have the lube I needed to get those rod bolts torqued properly. I used oil. Crower at the time sepcified oil but there was NO WAY you could get those bolts to their specified torque with plain oil. They would tend to seize up with plain oil that is likely what happened. Sometime later during the season a rod came apart and it was the one I had out. Luckily all we needed was a couple new pistons and rods.....The orginal problem was from a head that leaked water in an intake port.....
I experimented and made my own rod bolt lube...oil and moly paste mixed together......stopped the seizing as the bolts were tightened Crower supplied an anti-seize paste with later rods......as does ARP So My point is rod bolt lube plays a huge part in getting the bolts installed properly. I used a torque wrench for many years with no issues. I also have a rod bolt stretch gauge and have used it as well. Some rods like Olivers use an initial torque + a torque angle gauge to set the bolts......Olivers are the best in my opinion...... Another one is to make sure the bolts fit properly.......It is possible for the rod bolt head to not seat in the rod properly.....rare but possible..... I used Manley Sportsman rods in my LT-1 Stocker a few years ago...a very good rod for a SB Chev....and would probably be good in your application if you could get something to fit.....
#14 | |
EXCELLENT Info.
Thanks, I have heard of a new lube from ARP that is "torque agnostic" and well that "its the ****" I have to call them and see if its "all that" but yeah oil sucks, depends all on thread finish. Good info thanks. Quote:
#15 |
Liked 70 Times in 22 Posts
Chris
Look at the Manley #14460. It is approved and $$$$ since it is the only aftermarket rod approved so far. |
#16 |
Liked 1,874 Times in 422 Posts
I've put in at least a couple hundred sets of Eagle rods. The only rods I've seen broke were rods that were in cylinders that had the entire cylinder wall collapse. The rods were bent nearly double before anything broke. And those were the I-beam rods. I've never had a broken Eagle H-beam rod, in anything I've built personally (and I've built plenty with them), although I know some who have.
I know several guys better than me, with more horsepower than me, and turning more RPM than me, who use Eagle H-beam rods. We have Eagle H-beam rods in the iron 427, and a new set to go in the new iron 427. They are the Eagle 6.135" H-beam rod with L-19 bolts and the "ESP Armor" option. With a 750 gram piston assembly (counting the piston, rings, locks, spacers, and pins) and turning no less than 7800 on every pass, we've got no problems. If Eagle has an H-beam rod that will fit, get the L-19 bolts and the ESP Armor option, and get them approved, they should do fine. I know guys with 9000 RPM 850HP Super Stock engines with Eagle H-beam rods with L-19 bolts in them. If they wanted, or felt they needed, an Oliver or a Crower, I know for sure they can afford them.
Alan Roehrich 212A G/S |
#17 |
I can agree with Alan about Eagle H-beams......used them a few times and never had a failure. I had them in one of my own engines in my old dragster. Big Block alcohol injected 7 second car.......
I have seen the I beam SR rods fail though in a small block bracket engine with very few runs....
#18 | |
I need a 6.200 length and 927 pin .... Stewart (there is a 'problem' with the Manley rods, nothing structural just an issue regarding its legality in Stock from what I understand from well people who should know .... lol) Ill give you a call and thanks for the OP #'s
#19 |
Guest
Posts: n/a
I am going to say what others may be thinking, and don't take this the wrong way, but you need to align yourself with an stocker engine guy that knows what they are doing. Some of questions you ask, and some of the things you say about parts, rpm, and trick of the week coatings really scares me. If you don't, I'm afraid you may be in for a long, expensive education. If you do go it alone, then at least build just one motor to learn with, then if, or when, you have figured it out, spend money on the other motors you have planned. Again, don't take it as a slam, I'd just hate to see you have another oil pan failure.
Good Luck |
#20 |
Another piece of advice........ditch the oil accumulator......I really see no reason for one on a stocker unless your playing with very low oil in the pan or it is doing giant wheelstands.......Makes no sense to have one on a car like this to me for the little gain you might get. If you had one on there and were having oil pressure loss issues....something was definately plumbed wrong....
I have one on my dragster (3 qt Moroso) and it has at times shown some erratic operation on the pressure gauge.....I believe it was from mounting clamps that were to tight and in locations on the can that could restrict the pistons movement......I took it off and moved the clamps to the outer ends of the can but have not put it back on to see if it's fixed...... I have no knowledge or experience with the oil system on one of these Mopar engines and as I recall Mopars were a little less trouble free than your run of the mill Chevs.....
