Old 03-26-2010, 07:21 AM   #11
Greg Hill
Liked 279 Times in 68 Posts
Default Re: C-11 Cost?
Bob , all I did was swap gas. I remember when I started using c-11 I richened up my carb. I really think if I had taken the time to lean my carb up just a little there would probably of been little or no difference. This is a motor that is about 10.5 to 1.
Greg Hill 4171 STK
Old 03-26-2010, 07:43 AM   #12
Casey Miles
Liked 508 Times in 92 Posts
Thumbs up Re: C-11 Cost?
Unless you're on the cutting edge and trying to set a record or something of that nature, why spend double the money on C-11 when a $5.00 shoe polish takes up the slack?
I know that some of you guys are going to say that you need all the power you can get when it comes to class racing. My arguement is that NHRA has settled most classes by ignoring the correct factoring of car and engine combinations and gas wouldn't help you.
Casey Miles
248H
Old 03-26-2010, 08:36 AM   #13
mannymen
Liked 13 Times in 7 Posts
Is Sunoco Purple or Blue = to C11? and where can I get Sunoco in Toledo Ohio?
Thanks
Manny
N/A
mannymen is offline   Reply With Quote
Old 03-26-2010, 09:53 AM   #14
Tim Ellis
Liked 7 Times in 6 Posts
I thought c11 was unleaded, isnt it? And is the official name of the Sunoco purple "standard"?
Tim Ellis is online now   Reply With Quote
Old 03-26-2010, 10:10 AM   #15
Travis Miller
Travis Miller's Avatar
Liked 276 Times in 27 Posts
C-10 is unleaded and the purple Sunoco is called Standard
Travis Miller is offline   Reply With Quote
Old 03-26-2010, 10:28 AM   #16
Tim Ellis
Thanx
Old 03-26-2010, 10:38 AM   #17
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
Thx for the info....Just switching fuels and seeing a diference in mixture is good
info to have thx. Bob
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
Old 03-26-2010, 12:13 PM   #18
John Musial
Liked 51 Times in 3 Posts
Thanks
Manny
Try Corrigan Oil in Michigan. I know Bazell fuels is a distributor also.
Sunoco's web site for race gas www.racegas.com
John Musial is offline   Reply With Quote
Old 03-26-2010, 02:09 PM   #19
mopar jeff
mopar jeff's Avatar
Originally Posted by Phillip marvetz View Post
Well that is at least $100 less than jobber cost here. I guess I'm getting the shaft. Pacific raceways has sunoco at the pump but I'm not sure what they have for options. I guess I'll be taking an empty drum with me next time I head down there.
P.S Hey Sean I figured out how to use the quote finally. Now I'm as cool as you.......
I got it at Downs Fuels in Riverside.
Jeff Interlicchia
7077 D/SA 1998 Pontiac Firebird LT1
J707 E/T 1966 Dodge Coronet 500
mopar jeff is offline   Reply With Quote
Old 03-26-2010, 02:29 PM   #20
Casey Miles
The evaporation rate is what causes the carb to be riched or leaned. You can look up the spec's of the fuels on the net.
I spoke to the Sunoco people at the PRI show in Orlando, and they told me that the gas can be stored for up to 2 years and it will still pass as long as it's in the correct container.
Casey Miles
248H
