Liked 18 Times in 7 Posts
Never having run a small block I need a little help.
I have a 69 camaro small block stocker. I want to purchase a set of Moroso front springs. I have no idea what the front end weighs with a 350 Jegs lists two 1550-1640 or 1690-1750 Can anyone help me out here ? Thanks, Ken ` |
Liked 544 Times in 213 Posts
Ken.....I have usually had to cut even the lighter Moroso spring. My last Smallblock '69 Nova Stocker needed front springs. I believe I used the lighter Mororso spring and had to cut them twice to get a decent ride height. That car was a 350 with a p/g.
Liked 309 Times in 88 Posts
Ken, call me at 706-577-4272 reference springs and I have a question for you I would like to ask.
Jimmy Parker |
Liked 59 Times in 13 Posts
Ken -
I have a set of front springs from Santhuff Engineering that are setup for late 60's model Camaro's, Novas, Chevelles. I ordered them a couple years ago and never put them on. Once I tried to put them on I realized I ordered the wrong part number. I had to re-order the correct ones this week. So needless to say, I have a set of front springs that will fit your car that are brand new, never used. According to Gary Wisecarver, he puts these springs on cars and there is no cutting required. They are 18 in tall, 5 in outside diameter and rated at 200 pds. You can call Santhuff's to verify. Their number is 361-364-3169. Brand new these springs are $189. I would let them go cheaper than that. Call me if interested 417-437-1669. |
I would suggest the lighter of the two
Eric Bowling |
Ken,
You have the heavier of the 2 moroso trick springs with 1 1/2 coils cut off. I would go the santhuff route or call pete z in babylon ny . Good luck with the car. Greg Davis |
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
Santhuff with the correct spring rate is so much better that cutting a Moroso. We used to use Moroso trick springs and cut the coils to get our ride height. You can see photos at RinehartsPerformance.com to see our camaros stance. The front springs were never cut.
Marty Rinehart Jr 1125 SS STK SG SC SST |
Thanks Guy's
I went with Santhuff Ken |
Liked 1,893 Times in 423 Posts
![]() Ken, the orange car has Santuffs and small block springs, we're running the 427 with aluminum heads. You'll love how that stuff works.
Alan Roehrich 212A G/S |
