Old 04-16-2010, 02:39 AM   #11
Rory McNeil
Default Re: Ford guy questions about 429s
First off, there was never a Boss 429 Mach 1, the only Mustangs ever sold by Ford with a Boss 429 engine, were the 1969 & 70 Boss 429 Mustangs, which were NOT a Mach 1. Now, in 1971, there were Mach 1`s with 429 CJ or SCJ engines, but these are iron headed wedge engines, whereas a BOSS 429 has aluminum (semi) Hemi chamber heads. There is likely some confusion, as there were 429 Thunder Jet engines, as well as 429 Cobra Jet, & 429 SUPER Cobra Jet, and in some early literature, the Boss 429 Hemi was called the 429 CJ H.O.
To further muddy the waters, the 429 4 barrel Thunder Jet was rated at 360HP, the 429CJ at 370, the 429SCJ at 375, the Boss 429 was also rated at 375. The ThunderJet engines had hyd. cams and an Autolite 4 barrel carb, the Cobra Jet had a hotter hyd. cam, bigger valve & port heads, with a Rochester Quadrajet, the Super Cobra Jet used a solid cam and a Holley 780. In a 70 or 71 Torino or Cyclone, you could have gottern either the 429 ThunderJet, Cobra Jet, or Super Cobra Jet, in the 71 Mustang, only the CJ or SCJ were available. The only Cobra Jet available in a Mustang from 68 thru 70, was the FE 428. Now, wasn`t that simple?!
NHRA 6390 STK
M/S 85 Mustang
Rory McNeil is online now   Reply With Quote
Old 04-16-2010, 05:44 AM   #12
rayfin
I stand corrected. 70 Boss 429 Mustang with aluminum (semi) Hemi chamber heads.
rayfin is offline   Reply With Quote
Old 04-16-2010, 12:39 PM   #13
Bobby DiDomenico
Liked 101 Times in 52 Posts
Rory,
Don't forget the early 1969 production runs had the NASCAR based block and heads o-ring set up and the later ones and the '70's had the street engine o-rings which were reversed between the heads and the blocks on the T and S versions. Two guys here and them, one a Wimbledon (?) White with the track motor and the other a later Jade Green with the Street one. If memory serves me correctly the crank and rods were different as well when they rebuilt them.
Old 04-16-2010, 01:00 PM   #14
k.pascoe
Originally Posted by Bobby DiDomenico View Post
Rory,
The crank was the same between the two motors. There was the S rod motor a very heavy beefy rod, but shorter that the standard 429/460 rod. There was also two styles of boss head; the full hemi chamber (for superspeedways) and the squished chamber.( for the short tracks).
BTW -The 1971 police motor was a 429 CJ.
k.pascoe is offline   Reply With Quote
Old 04-27-2010, 08:23 AM   #15
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
Yes, this is the market ballpark. EBay would be the best place to sell.
X2...
flea-bay is the best place to gauge what anything is worth at that particular time
Also, try this hard core 429-460 site;
http://www.429-460.com/forum.htm
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 04-27-2010, 11:34 AM   #16
BlueOval Ralph
Banned
The full hemi was run all tracks at one time, the last time I checked the SK book there wer 28 different NASCAR heads the Boss 429 street had orings in heads NASCAR had orings in block decks
BlueOval Ralph is offline   Reply With Quote
