Old 06-16-2010, 05:34 PM   #1
5798camaro
Default caltrax or Cal Mathad
Which is a better system for a 71 duster? What's the cost difference between the two? how hard are they to install each of them ? What is is the advantage to them over regular leafs ? Thanks for your time. Sorrry Cal method
5798camaro is offline   Reply With Quote
Old 06-16-2010, 09:28 PM   #2
Liked 1,929 Times in 434 Posts
Default Re: caltrax or Cal Mathad
Cal Mathad? You mean Cal Method?
Old 06-16-2010, 10:33 PM   #3
5798camaro
Yes thank you
Old 06-18-2010, 05:09 PM   #4
Rod Greene
Liked 242 Times in 81 Posts
Nothing better than Cal Tracs on an A body Mopar.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 06-25-2010, 12:03 PM   #5
mike natoli
mike natoli's Avatar
Liked 51 Times in 16 Posts
Cool Re: caltrax or Cal Mathad
I can't answer your question totally only that I have used the S/S springs with very good success just by setting pinion angle, discarding the snubber, and clamping the front segments of the springs with a set of 12 way adhustable QA1s. I run a 30"X9" Hossier radial with 21 psi and usually hooks real well. Weight distrubution @ 50/50. However the spring life lately has been awful so I swithced to the Cal Tracks with split monoleaf springs. The installation was a breeze and the car feels stable on the big end. I did not see any increase in ET but not enough data maybe picked up a little on MPH by getting the tail down. I should mention this is a foot brake car with a 340 30over steel headed coupled to a SELECT converter and 904 with 5.13s. The car has not done big wheel stands since. Hope this helps you in your decsion. I switched to them just because someone like John Calvert has tried to build a better mouse trap.
mike natoli is offline   Reply With Quote
Old 06-25-2010, 05:18 PM   #6
Jeff Lee
Jeff Lee's Avatar
I've run Tri-City Launcher springs with and without Cal-Tracks and then Cal-Tracks with the split-leaf. By far the Cal-Track bars with the split leaf was the best move for me. You will reduce your leaf spring weight by about half when you go from a multi-leaf spring (especially if you had a stiff / race multi-leaf such as a SS Mopar spring) to a split leaf from Calvert. That weight savings can be placed right back in the trunk where it does the most good.
Jeff Lee 7494 D/S '70 AMX
Old 06-25-2010, 05:29 PM   #7
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
do you know if they'll do a 2" wide split leaf?
(too late in the day to call 'em....(i know they'll do the bars in 2")
Old 06-25-2010, 08:05 PM   #8
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
Yes.
For limited applications.
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
