Old 07-02-2010, 10:05 PM   #1
Chad Rhodes
Default 82-92 Pinion Angle
Any suggestions for a starting point on an 82-92 F-body Stocker
Chad Rhodes 2113 I/SA
Old 07-03-2010, 06:28 AM   #2
Billy Nees
Default Re: 82-92 Pinion Angle
That would depend on whether you are using the torque arm or the lower arm "ladderbar".
With the torque arm you will need less angle.
Billy Nees 1188 STK, SS
Old 07-03-2010, 08:23 AM   #3
Chad Rhodes
its got a torque arm, not a stock one though obviously
Old 07-03-2010, 08:51 AM   #4
Billy Nees
If it's an adjustable arm , I would start with the same angle as the trans to driveshaft angle. With that long an arm you don't need much. If your trans to driveshaft is nil then I would go with about 2 or 3 down.
Old 07-03-2010, 09:07 AM   #5
Chad Rhodes
thanks
