Old 07-05-2010, 07:43 PM   #51
SSDiv6
Liked 1,583 Times in 582 Posts
Default Re: Why did nhra change the cam and valve spring rule in 1985?
Originally Posted by Rick Leininger Jr. View Post
IF you use the ceramic lifters.
Yep...in the past I have addressed the subject of valve train dynamics and camshaft lobes in the Tech section...there is a lot more on new camshaft designs that do not require the high spring pressures being used today...
Old 07-07-2010, 01:29 AM   #52
mopar68
mopar68's Avatar
Liked 44 Times in 27 Posts
Originally Posted by art leong View Post
I believe they changed the cam and valve spring rules. For 2 reasons
1 The GM guys were constantly crying because Mopar wrote "bogus" numbers for thier cams
The GM guys always "cry" when they don't have the upper hand; perfect case in point: Pro Stock 1970-71. Nobody cried (read Mopar) to the extent the GM boys did during Mopar's dominance (read: Ronnie Sox--only one racer!) heyday. When the Grump cleaned up in 1972 and to a lesser extent in 1973 then the Fords of Bob Glidden and Gapp & Roush started dominating, we didn't get anywhere near the anti-Chrysler-type whining by both racers and the press when other makes where dominating thanks to the less lbs./cu.in weight (and shorter wheelbase) advantage.
Back to Stock Eliminator: bad move on the NHRA's part in making this rules change.
M68
Old 07-07-2010, 01:47 AM   #53
mopar68
mopar68's Avatar
You guys are forgetting the fact that many of the current crop of racers would have trouble just getting the valve covers off. Forget about monitoring spring pressure.
Ha-ha-ha...YOU'VE GOT THAT RIGHT!
How pathetic...
M68
