Old 07-31-2010, 03:17 PM   #1
Jody Noble
Default generator exhaust
What type of tubing are you guy's using to exit gen. exhaust above your trailer/motorhome?
Jody Noble is offline   Reply With Quote
Old 07-31-2010, 04:07 PM   #2
Mack Reeves
Mack Reeves's Avatar
Liked 44 Times in 13 Posts
Default Re: generator exhaust
That's the one I use......
Mack Reeves
2377 STOCK & SUPER STOCK
Old 07-31-2010, 04:40 PM   #3
art leong
I use 2 pieces of 3 inch PVC pipe Works great And I don't have a solid 10 foot section to deal with.
Art Leong 2095 SS
Old 07-31-2010, 07:15 PM   #4
FED 387
Liked 333 Times in 180 Posts
We made our own using ABS PVC and a 90* exhaust pipe from the local auto parts store --Cost me about $15-18 hours and took me about 1-1 1/2 houra to fabricate mine
Old 08-01-2010, 07:07 AM   #5
340Cuda
Liked 801 Times in 338 Posts
I have a Honda EU3000 which exhausts through a grill. It does not really have an exhaust pipe.
Anyone seen a rig that works with somthing like that?
Thanks,
Bill
Old 08-01-2010, 07:49 AM   #6
FED 387
I believe that the small carry around gens like yours are exempt from the ruling---It's the permanently mounted motorhome (onan/generac/kohler) generators that they are trying to enforce---With the portable gens you can relocate them away(like 20 feet in front of) from where the motorhomes are. That way your exhaust is not blowing right into some guys windows or his trailer/pit space. Comp387
Old 08-01-2010, 08:26 AM   #7
Larry Munk
A while back someone suggested using the electrical conduit bends that you can get at Lowes/ect.. They work very well and have a much nicer bend then the auto store stuff.
Larry Munk is offline   Reply With Quote
Old 08-01-2010, 06:51 PM   #8
rod
Liked 20 Times in 15 Posts
run the metal bend up into the 2" ABS, several inches. leave the air gap around the bottom. makes a small suction, pulls in fresh air and cools the temp. run the ABS way past the top of the roof.
glue a coupler to one section. the end of the other pipe which will go into the coupler needs to be sanded down so it will remove easily.
you could also fab up an adjustable 'leg' to support the ABS
rod in AZ
rod is offline   Reply With Quote
Old 08-01-2010, 06:59 PM   #9
Rob Petrie E395
Liked 216 Times in 77 Posts
Originally Posted by montys 55 View Post
Same one here too. Works great on my trailer with 2 ft extended hight but on the toter it will not reach up to the top.
