I have a set of 840 casting and I haven't had a chance as of yet to get them flowed, does anyone here have or know the 840 specs
Flow Numbers Combustion Chamber size(s) Thanks for the help Phil Rowe
Phil JPR Motorsports 1972 Nova Street Strip Project |
Knowone really knows anything about these heads, Thanks anyway
Liked 16 Times in 11 Posts
According to the tech sheet they are 114.9 cc chambers
Bob Pagano A/SA |
Liked 13 Times in 7 Posts
Liked 18 Times in 9 Posts
Phil,
The 840 castings are rect. port heads with 2.19 int. and 1.72 exh. valves. They are closed chamber heads at 104.9 cc. Flow #s all depend on what you do with them as far as valve job and port work. |
#6 | |
Ron thanks for the advise but I would hold and trust the word of those from this site that might be using them current or in the past over and above your recommendation. But thanks again for your reply. Phil
#7 | |
Thanks again, phil
GearJammer, For those running 427/425HP with a cast iron head in Stock & SS you will find that most run either the 840 or 291 head.
N/A |
#9 | |
Phil
Liked 1,912 Times in 429 Posts
If this is a street pump gas engine, with no rules, you'd be better off to sell those heads to someone who needs them, and buy a set of small chamber Edelbrock aluminum heads.
A 60499 Edelbrock, out of the box, has a 100cc chamber, 2.19 and 1.88 valves, and flows 300 cfm @ 0.600 lift on the intake, and 218cfm @ 0.600 lift on the exhaust, with no work. All new heads and all new parts. A good shop doing a 3 angle valve job, new guide liners, cleaning, milling, and assembling the 840 heads will charge at least around $500 labor. That's without hardened exhaust seats for unleaded pump gas (I ended up putting a full set of 16 seats in my early model BBC heads for another $300, plus redoing the valve job after trying to run old heads on unleaded pump gas, because it sunk several seats, intake and exhaust). That also doesn't include about $500 for new valves, springs, retainers, keepers, and seals. I'm not trying to tell you what to do, just offering free advice from hard earned experience.
Alan Roehrich 212A G/S |
