Old 09-09-2010, 08:53 PM   #1
JSLRacing
Default Distributor
Do you have to run a factory dizzy or can you convert to a crank trigger set-up in stock with a carburetor car ?
Jason Goldsack -
1997 Track Champion - St. Thomas Dragway
1997 Race of Champions Winner - Indianapolis, IN Div. 3 finals
JSLRacing is offline   Reply With Quote
Old 09-09-2010, 09:04 PM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: Distributor
Only if the engine came with a crank trigger
Jeff Lee 7494 D/S '70 AMX
Old 09-09-2010, 09:08 PM   #3
JSLRacing
OK...that makes sense..
I was just curious.. I guess that also gives the EFI a bit of an advantage.. Anyone modify a dizzy for a hall effect pick-up?.
Jason Goldsack -
Old 09-09-2010, 10:20 PM   #4
Rick Unterseh
Rick Unterseh's Avatar
Liked 31 Times in 7 Posts
I have run the Mallory Unilite for YEARS.... and no problems, knock on wood. The Mallory unilite is the "hall effect" design. The biggest problem with them is the ground. DO NOT ground them to an aluminum intake or anything aluminum. The block and or the frame is the best ground possible. They are easy to lock out if that is your thing too.
Rick
Rick Unterseh is offline   Reply With Quote
