#61 |
Liked 120 Times in 41 Posts
Dave Bortman ran a shaker set up with a 383 on his 1970 Rod Shop Challenger, and did quite well in SS/JA.
#62 |
Banned
Liked 235 Times in 110 Posts
I believe Boertman's car was a 71 383 with the small Holley carb???? Mine was a 71 383 and it had a shaker hood and "scoop-ayyy" on it. I ordered it new in the early spring of 71 just for racing. No other options other than the hood, an automatic, tinted glass, and posi rear. NHRA probably allows them on the 70 383 model as the street Hemi 'Cudas had them. NHRA seems to allow "scoop-e's" on everything else.
#63 | |
Liked 61 Times in 12 Posts
John
John Bender 1969 STK |
#64 |
On the Cuda yes, Although they only came on Six Packs and Hemis. But can I claim the car as a 383 Barracuda and use the shaker. ?
2009 V/SA Record Holder |
#65 |
Liked 10,969 Times in 2,261 Posts
Phillip, If you will look at the engine specs. for thr 1971 Chrysler you will see it list two diferent carbs for the 383/ 300 hp. its under note 4. I think its a 6191 list for auto 4668 list for the stick. The 340 even had a shaker along with the 1970 440/ 370. Hope this helps.
#66 |
Thanks Larry, My question is regarding a 1970 Barracuda not a 1971 Cuda though.
P.S I finally bought some new radial slicks for the Coronet but they didn't help although it is going thru the traps with more RPM now, Enough to get back into valve float again.aaarrrggghhhhh!
#67 | |
Liked 4 Times in 4 Posts
When I came home from my Southeast Asian vacation I bought a new '70 Cuda with 340, 4sp and a Shaker Hood. If the 340's had them then I'm sure the 383's had them. JimR
Jim Rountree |
#68 |
Liked 24 Times in 14 Posts
FR-------S don't worry we will have the YENG--ling and bring the 66 Dodge it's probably factored better than the 68 R/R JUST LEAVE THE SCOOP HOME BECAUSE YOU KNOW THAT NO SCOOPS IN 1966 NOTHING !!!!!! Bender is doing much better, he even came out to E-TWN - watch what you say spies may be watching YOU !!!
Frank Bialas 1570 STK |
