Old 09-15-2010, 02:45 AM   #11
Paul Wong
Liked 419 Times in 85 Posts
Default Re: A New question to DP and Mustang Owners only
The 69 440-6 has numerous differences from the 70 440-6. Flat top pistons with no valve relief but then again its not 411 hp either. The 69 is 395. This is still a combo that has potential to perform very well. probably a good 10.50 C car. Too bad it probably could not run with the 5.9 drag pak at 284hp
Paul Wong is offline   Reply With Quote
Old 09-15-2010, 02:46 AM   #12
Liked 5,131 Times in 1,956 Posts
Originally Posted by Jeff Lee View Post
The '70 GTX / Roadrunner has the small "air grabber" hood scoop (the one that pops up).
The '69 Roadrunner gets the fiberglass hood with a big ole honkin' scoop.
The 70 has more compression.
Old 09-15-2010, 05:47 AM   #13
GTX JOHN
NOT MUCH piston to valve clearance on 69 due to flat tops without valve relief. It would not accept a camshaft as aggressive when I ran the combo in mid 70's
Old 09-15-2010, 09:04 AM   #14
Andys dad
Andys dad's Avatar
Liked 175 Times in 78 Posts
I am a Chevy guy but -
I think Jeff Teuton knows what he is doing and I think his point is well taken
Finally he has a combo that is very fast
I doubt his "stuff" was ever slow do to lack of effort or money
Old 09-15-2010, 09:12 AM   #15
Frank Bialas
Frank Bialas's Avatar
Liked 23 Times in 13 Posts
Originally Posted by RULER View Post
Jeff, is this the same 440/6 pack that Mr. Wann ran in his GTX, if so then may be you need to look at your car or engine builder because if i remember seeing some Q-sheets a few years ago he didn't lose many heads ups and was always a top qualifier.
A FEW YEARS AGO THE 70 WAS AT 405 THAN 411 NOW AT 417 HP, don't even think about HIDING OUT IN C/SA min. wt. 3920, that's why the combo is no longer competitive.
Jeff the BIG hole in the hood isn't worth all that much, but I do like the plastic hood on the 691/2 for weight off the nose.
Frank Bialas 1570 STK
Frank Bialas is online now   Reply With Quote
Old 09-15-2010, 09:28 AM   #16
Casey Miles
Liked 508 Times in 92 Posts
The point of the question is that the newer cars are all out of whack to the playing field of the older cars and what can be done to correct the situtation. NHRA should have put at least 100 hp to all the new combo's (DP's and CJ's) and let them loose HP as they fit into classes to be competitive. The way that they are introduced to the playing field is so out of line, that it is an embarrasment to NHRA to let it go on. I was at Indy watching the older cars that used to be competitive fall to the way side as the newer cars just ate up all the quailifing positions. Cars that where .6 and .7 under, which used to be almost 1. under, couldn't even see the top of the quailifing sheets. It was a total mockery of the HP system and a fair playing field.
Just an observer of what went on at Indy, for the racer it was a $320 entry fee to watch your combo got to the crapper!
Casey Miles
248H Stock?
Old 09-15-2010, 11:29 AM   #17
Larry Curtis
Larry Curtis's Avatar
Liked 9 Times in 2 Posts
The 6.1 hemi has been running in the NHRA the longest of the Challengers. At Indy the fastest 6.1 pass was 9.98 in A/AS by Doug Duell. That is 1.02 under the index, does this warrent it being put into a FX class? I am the point in my build where I can switch to a 5.7 at almost zero extra cost, but I am still going to build the 6.1. I want to compete in A, I would try to go to AA but I can not compete against a blown Mustang.
It appears to me that the AHFS is catching up with the 6.1 Challenger (not fast enough for some, but it is getting there).
Just my $.02
Larry
Larry Curtis is offline   Reply With Quote
Old 09-15-2010, 11:37 AM   #18
Dgal
Just my $.02
Larry
This is what warrants the placement of it into a FX class (in addition to internal things).
Dgal is offline   Reply With Quote
Old 09-15-2010, 11:48 AM   #19
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Talking Re: A New question to DP and Mustang Owners only
Just my $.02
Larry
Do ya suppose that Doug was 1) short shifting 2) running heavy 3) "Dumping" before the finish line 4) running it detuned 5) or with the A/C turned on or all of the above????? LOL
Old 09-15-2010, 11:50 AM   #20
MikeFicacci
Liked 19 Times in 2 Posts
This post started with someone asking if anyone had a problem with FX classes and Jeff Teuton responding to the effect of 'what's wrong with my being a half second faster than the fastest G car on the planet when I used to be down a half second to the rest of the C cars'. I was simply trying to gather information on his combination because based on the few guys running a 440-6pack in the GTX against the normal cars, I would think that Jeff forgot a plug wire or two. But, it appears that I am incorrect and it is a different combination.
Mike Ficacci Stk 1010
MikeFicacci is offline   Reply With Quote
