#31 |
Liked 11 Times in 2 Posts
Well said, Bill.
#32 |
Liked 325 Times in 50 Posts
There is plenty to these new cars. That from a real old car guy. But the total adjustability is what makes them a little hard to duplicate. I could go into the detail about Throttle Position, Timing Change going down the track (did I say MSD Digital), fuel pressure (critical to a EFI, a carb only needs supply) gliches, gloches, etc. Dan Fletcher went back to a carb car. Now for fact not fiction. My ss EFI 360 motor makes 10 more hp and 12 more tqe with a race 850, than a 1000 cfm Throttle Body and Fast EFI system no matter how you adjust them. A comp motor of say 850 hp will probably make 20 more. I was surprised so i confirmed that with several guru's and suppliers around the nation. Seems starting the atomization in the venturi has a better effect than injecting solid fuel at the bottom of the runner. The EFI systems of today evolved from the need for EFI on factory cars because of driveablity and emissions especially in view of the unleaded and weak fuel we run driving around. Total adjustablilty, such as the factory system that adjusts timing and fuel in microseconds makes a car run well. I think we have about 100 sensors that inform the motor what is happening while driving. At wot, most of these sensors are ignored. I'm lost. I quit for now.
Jeff Teuton 4022 STK |
#33 |
Larry, you are mistaken about taking power out effecting 60' times. If you use an MSD Digital 7 Programable box you simply back up the timing in the upper gears. That way there is also no effect on your lights, like a lot of weight would. You can do that to older carbureted cars also. No rocket science involved.
Ed Wright 4156 SS/JA |
#34 | |
Chad Rhodes 2113 I/SA |
#35 |
With a drive by wire system, this is very doable. But to make it accurate the car would need some sort of a real time feed back to track the car as it progress down track. GPS would work, they are getting faster all the time, but what most automotive company's use for brake testing is a optical sensor that bounce's light of the pavement (they use to use a fifth wheel for this input) and the programing for this kind of a system would not be that complicated.....
That being said, in my humble opinion......just by the win column on the new cars that are using drive by wire.....it doesn't appear that anybody is using it. maybe Nitro Joe could shed a little light on the stats for new cars winning rounds or races
67 Ford Fairlane F/SA 749 |
#36 |
Liked 70 Times in 22 Posts
Larry
I could be wrong but I read the 2009 rule different that you are. It does not rule out DBW. It states that "electronics, pneumatics, hydraulics, or any other device may in noway effect the initial throttle operation.". That is followed by DBW. The key word is initial, or first, operation. That required initial operation is the drivers foot pressing the pedal. After that motion there is no rule barring electronic, pneumatic or hydraulic. The same rule paragraph even speaks of the use of hydraulic specifically. That said, what is not allowed except in the Super classes is the "use of....electronics to modulate the throttle after initial launch.". There is the problem, how to prove that is or isn't being done. As Ed points out, you can slow the car with the MSD , or I imagine with the on board computer, just not electronically with the throttle AFTER the initial hit. Having 100% pedal being 100% or 80% or 60% throttle position is legal, but you have to pick one and use it the whole run. Timing is a different story. The key will be how the 2011 rule reads after the January revisions. Speak now to NHRA. As usual, my disclaimer. "I could be wrong".
Stewart Way 2424 SS |
#37 |
Liked 49 Times in 15 Posts
I think the point that needs to be made is that when using a drive by wire, the computer is running the throttle plate via a DC motor on the side of the throttle body. True in stock form, the computer uses inputs like the APP (accelerator pedal positition) to determine where it wants to drive the throttle plate position to. But it also looks at many, many other inputs to determine not only what the driver wants for throttle, but what the vehicle needs for throttle. On a drive by wire system, the PCM gives you the throttle IT thinks you need, not always what you want.
The fear is that the PCM can be used to drive the throttle plate in throttle stop like manner. As stated earlier, if you need to slow the car down, program the PCM to only open the throttle plate 70%. No popping, no banging, no fancy ignition box, no fancy tach, just down on power. Or perhaps you cannot cut a light. Program the PCM to open the throttle 1.5 seconds after the APP sees you smash the gas on the top bulb. I am no computer programmer. But I have been a Chrysler tech for 23 years. I am well versed on these systems. Personally, I believe it would be very easy for someone like me, who knows how the factory stuff works, to team up with a good computer guy and make a controller that could do this stuff.
Dean Feiock -- Stock 5002 |
#38 |
As far as DBW and safety is concerned Toyota didn't have the proper defaults in their programming to eliminate a possible open throttle failure.....most OEM's run DUAL TPS sensors on the throttle blades, one to follow the throttle position as to the pedal position and the other to verify that this indeed happened and if not to throw the engine into a "limp" mode to allow control until it can be repaired.....it would not be difficult, as some have mentioned, to program this system to do anything you would like to try and the best part is it would be undetectable and if properly done impossible to find.....sort of like a "ghost in the machine"....
As a journeyman industrial machine builder, I have seen and used some really interesting and versatile micro sensors, software, and inovative programming techniques to accomplish many issues relating to automated industrial machines.....and now that sensors, computers and software are being used to control an automotive "machine".....good luck....the only limiting factor is ones imagination..... D L Rambo.... |
#39 | |
Liked 125 Times in 40 Posts
Sean Cour T6066 ladle |
#40 |
First, you can move the pedal faster than the little motor moves the throttle blade(s), I get that compaint all the time from guys trying to cut lights when foot brakingate model DBW cars. Not a method you would want to use with a "1.5 second delay off the top bulb. Guys need to understand that you can't just do that without a look-up table in the software for pedal response delay. (they do not exist in OEM ECUs) maybe with some aftermarket ECU, not the factory stuff. Getting a school kid to write something for a P.C. is one thing, a Ford, MOPAR or GM computer is another. Want to close the throttle at higher MPH or RPM? They do not contain look-up tables for that either. No look-up table for that? Then you can't make it do that. Guys throwing this stuff out obviously don't do this kind of work. I get some pretty silly requests, they seem to think it's the same as programming a P.C. No college or night writing an operating system for a Ford ECU so you could add all the look-up tables to do those things. Might get a Ford calibrator to have it done.
