So.. as we embarq on year # 2 of S/ST racing and begin to plan the calendar, I have a question I am sure someone here can assist with. Sorry if it is posted elsewhere, but I searched and can't locate the answer.
Is it necessary to be invited or qualify via divisional points to run at a national event? If so, what is the criteria? Thanks! Last edited by 65Shoebox; 01-02-2011 at 04:40 PM. Reason: typo |
Liked 3,232 Times in 983 Posts
See the link for how the grade point system works, no qualifying per se but you pre-enter per the schedule (when you can enter based on your qty of grade points) up until the quota estalished by NHRA for the particular category at that race. You just need to successfully tech in at a divisional or national open event to earn a grade point.
http://www.nhra.com/story/2005/1/21/2537/
Banned
you send them money and then your invited.
Thask for the link and explanation. Is it often that people are turned away in S/ST?
#5 | |
http://www.nhra.net/apcm/templates/n...=2537&zoneid=8
Chris Williams 6304 SC, TD, ET |
Only way you can get turned away is if they've reached the quota for that event. Think Seattle and a few others fill up but normally you can get in with a single grade point ( S/ST is competed in only one event per division so there's less chances for those racers to run Nationals).
Thanks much guys. We hope to run all the D2 events, so it sounds like we may be able to make it.
Happy New Year! See you in Bradenton. |
