Old 01-04-2011, 01:56 AM   #1
Walt Reynolds
Walt Reynolds's Avatar
Default Firewall Flex 67-69 F Body
Has anyone experienced firewall flex in a stick car and if so what is the recommended repair?
Walt Reynolds is offline   Reply With Quote
Old 01-04-2011, 09:36 AM   #2
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: Firewall Flex 67-67 F Body
Moroso used to make a brace that bolted to the two bottom master cylinder bolts and extended to the subframe to help prevent firewall flex for the clutch pedal pivot. It's an old part (like me. Only I'm an old fart!), from the 70s. Is that what you are talking about?
Old 01-05-2011, 11:42 AM   #3
Walt Reynolds
Yes. I just emailed Moroso to see if they have anything like that. Thanks for the info. If they don't have anything I will have to fabricate it myself.
Old 01-05-2011, 04:27 PM   #4
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: Firewall Flex 67-67 F Body
I've seen Chevy II racers make a brace that runs from the master cylinder to the top of the shock tower. Theres quite a bit of movement on those cars,,up to 1/2 an inch with the old heavy clutches we used to run back in the '70s,,,maybe its better with the modern clutches.
Danny Durham
Old 01-06-2011, 11:40 AM   #5
jim powers
jim powers's Avatar
Liked 13 Times in 10 Posts
jimmy parker has a great working brace for this application pm him here
jim powers is offline   Reply With Quote
Old 01-06-2011, 02:49 PM   #6
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
My guess is you have old 2800-3200 lbs. pressure plate? If so take it out get a good clutch setup that will fix your firewall flex and save every driveline piece in the car.
Mike Taylor 3601
