Old 02-13-2011, 11:15 PM   #1
BRIAN SEATE
Unhappy Holley fuel pressure regulator issue
I was flushing the lines on my Camaro when I noticed a fuel leak from the bottom of my new Holley big port regulator. The fitting came with the kit, everything was tight. I even used paste after trying first with teflon tape on the NPT coming in from the bottom. Never run into this with a regulator, was getting late called it a night. Could it be a cracked fitting or cracked regulator. Anybody ever had bad regulators or fittings out of the box? Gonna get a fitting Monday at the local speed shop and start there. Nothing was over tightened, put several on in the past. Thanks for any input.
BRIAN SEATE is offline   Reply With Quote
Old 02-13-2011, 11:39 PM   #2
james schaechter
Default Re: Holley fuel pressure regulator issue
Not sure on the holley, but on the MagnaFuel and Product Engineering ones that I have used, the fittings require an O-Ring to seal up. Worth checking out if you haven't already.
James Schaechter 3163 STK
Old 02-14-2011, 06:12 AM   #3
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
I have had the Holley reg. crack at the casting seem......
Old 02-14-2011, 09:33 PM   #4
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
I bought a Summit branded (remanufactured Holley regulator) and right out the box it had a pin hole in the casting. As soon I turned on the pump it had a tiny stream that shot out about 8 inches.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 02-15-2011, 12:34 AM   #5
Jeremy
Regulators are thin at the threads and will crack at the threads if they are tightened very much.
Jeremy is offline   Reply With Quote
Old 02-15-2011, 01:13 PM   #6
njk53
Send the Holley back and buy an Aeromotive. Good quality stuff.
Nelson Kowal
Stock 345
Old 02-15-2011, 01:56 PM   #7
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Holley fuel pressure regulator issue
Originally Posted by njk53 View Post
send the holley back and buy an aeromotive. Good quality stuff.
x2
Old 02-15-2011, 10:03 PM   #8
hemidup
x's 3
Jerry Williams
NSS/A, E/S, PRO E.T. And the "Grandaddy" of Gen III Hemi Performance...The fire inside me still burn's.
hemidup is offline   Reply With Quote
Old 02-16-2011, 06:08 AM   #9
rallye bob
rallye bob's Avatar
X4
Where were you guys when I needed you? LOL
